Liberty3 v2.0 - Boot Problems & Recovery...
This is a discussion on Liberty3 v2.0 - Boot Problems & Recovery... within the Team Liberty forums, part of the Gingerbread Roms category; Ever since flashing to Liberty3 v2.0, I have had a problem with boot up every once in awhile that would require a battery pull to ...
Thread: Liberty3 v2.0 - Boot Problems & Recovery...
    Points: 1,584, Level: 22
    Level completed: 84%, Points required for next Level: 16
    Overall activity: 0.8%
    swartlkk's Avatar
    32705
    101
    Ever since flashing to Liberty3 v2.0, I have had a problem with boot up every once in awhile that would require a battery pull to get it to boot up fully. When it won't boot, I will get the initial screen (green android for me at this point) and it will then go to a blacked out screen with the screen still on. It will stick there indefinitely if I let it. As a result, I cannot access recovery from the power menu... Any suggestions on fixing this? Will the stock recovery allow me to do a complete backup?
    Other than this one hangup, I am very pleased with the ROM. I'm consistently getting 36hr battery life with it throughout the week and at least 24 hours on a weekend. Up from ~20hrs during the week & ~14hrs on a weekend. It is also much more responsive than stock which makes it feel like a new phone all over again!
    Thank you to all who respond in advance!!
    Points: 22,755, Level: 93
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    Try unchecking or checking USB debugging. I bet it's at CWM but its checked so it wont fully bboot into it.
    But no stock recovery wont create a nandroid backup.
    FreeMyMoto!!!
    FreeMyMoto!!!
    If you need help PM me!!!
    swartlkk's Avatar
    32705
    101
    Look at that! Never gave it a thought. That worked like a charm. I wonder if it'll fix the boot up problems as well. Thanks for the quick response! Now I can back up everything before trying something new.
  1. Can't boot into recovery
    By Jdec in forum Droid X2 Support
    Last Post: 12-11-2011, 10:31 AM
  2. Replies: 4
    Last Post: 09-28-2011, 10:27 PM
  3. Replies: 5
    Last Post: 06-09-2011, 12:43 PM
  4. Replies: 8
    Last Post: 01-13-2011, 11:16 PM
  5. Recovery problems!
    By lthelwpn in forum Droid X Help
    Last Post: 12-26-2010, 09:03 AM
droid x liberity 3 v2 boot loop
droid x liberty 3 v2 boot loop
droid x womt boot after flashing liberty3 v2
how to fix liberty3 v2.0 3g
liberty 3 v2 droid x2 boot loop
liberty3 rom bug fix
liberty3 v2.0
liberty3 v2.0 for droid x2
liberty3 v2.0 rom droid x battery issues
problems loading liberty3 v2.0 on droid x2
