Need cyan battery icon
This is a discussion on Need cyan battery icon within the Off-Topic Discussion forums, part of the Off-Topic Area category; I'm using liberty 3 v2.0. I have everything themed to cyan. I cannot get the battery icon to the cyan color. Checked rom toolbox, then ...
Page 1 of 8 1 2 3 ... LastLast
Results 1 to 10 of 75
Thread: Need cyan battery icon
    Points: 1,633, Level: 23
    Level completed: 33%, Points required for next Level: 67
    Overall activity: 9.4%
    nemesisdxer's Avatar
    22938
    151
    I'm using liberty 3 v2.0. I have everything themed to cyan. I cannot get the battery icon to the cyan color. Checked rom toolbox, then to icon changer, but no 1% increment cyan battery icon. Suggestions?
    Sent from my DROIDX using Xparent Cyan Tapatalk
    Themer
    Points: 10,004, Level: 66
    Level completed: 89%, Points required for next Level: 46
    Overall activity: 85.7%
    BHuber09's Avatar
    34670
    Atlantis
    3,347
    60 times
    Send me the framework-Res.apk and Systemui.apk ill make you some.
    FreeMyMoto!!!
    FreeMyMoto!!!
    If you need help PM me
    22938
    151
    Bit of a noob. I know what icons I want (regular battery skinny bar icon that comes as the default icon in gingerbread -same as below-, and the wider bar that's comes in default in the Samsung nexus). How would i find these two APKs from above and how do i send them? My homescreen with the blue battery.
    Themer
    BHuber09's Avatar
    34670
    Atlantis
    3,347
    60 times
    So do you want the exact same as tthe ones you have but in cyan or would you like something like this but in cyan.
    But as for the apks go into file explorer. Go as high as you can (/) then go to system (/system) then app (/system/app) and copy Systemui.apk to your SD card. Then go to /system/framework and ccopy framework-Res.apk and copy that to your SD card. Then upload it to something like dropbox and send me a link to download it.
    FreeMyMoto!!!
    FreeMyMoto!!!
    22938
    151
    OK. I will get started tomorrow afternoon. Have work early morning. I was wondering if i can have both styles, if not, i would like the style you have uploaded (wider battery) but with number in white to the side of the battery like in my pic.. if possible. Thanks for your help and cooperation. No hurry.
    22938
    151
    (For BHuber09): I now have both of the apk files saved in dropbox and will be sent out as attachments. Do I need your email address to send them to you? Thank you bud. (Just remember my battery icon uses 1 increments with my liberty rom, not 10.)
    Themer
    BHuber09's Avatar
    34670
    Atlantis
    3,347
    60 times
    Okay in dropbox if your on a PC download it and go to downloads and whatever the link was used to download it send it to me. If on your phone click share and copy link. Once I get the link ill work on them tonight around 7ish I'm busy up till then.
    But I can make both for you but you'll only be able to have one. Ill make both as seperate zips so you can just flash whichever one you are in the mood for.
    FreeMyMoto!!!
    FreeMyMoto!!!
    22938
    151
    OK. I'm at work now, so I'll send the links this evening. And no hurry on this. Take all week if need be. Thank you again.
    22938
    151
    Here are the two files: (if. they don't work, I will have to email them to you if you give me your address. Let me know.)
    http://db.tt/CRsWUwoT
    http://db.tt/ZKSjK19M
    For the icons: the 'skinny' battery bar icon with the 1% increment number to the left of it as I posted in my Jan. 8 pic only in cyan of course.
    For the 'wider' battery bar icon, it will be the same as below:
    The 1% increment numbers (in white) inside the cyan battery icon.
    Again, take your time with this...Thank you so much!
    Themer
    BHuber09's Avatar
    34670
    Atlantis
    3,347
    60 times
    Haha alright man ill get that done for you. But I don't know about tonight I made plans before I realized it was bsc bowl day. Ill for sure have it to you by tomorrow
    FreeMyMoto!!!
    FreeMyMoto!!!
  1. Eclipse cyan hex wanted!
    By Nickolas in forum Droid X2 Themes
    Last Post: 10-02-2011, 10:32 PM
  2. Replies: 33
    Last Post: 03-22-2011, 06:34 PM
  3. Help! Looking for a full cyan theme for liberty
    By r1unknown in forum Droid X Themes
    Last Post: 01-30-2011, 05:48 PM
  4. Any cyan or light blue themes?
    By Gerane in forum Droid X Themes
    Last Post: 12-30-2010, 07:05 PM
  5. Battery % Shown in Battery Icon in Status Bar
    By asctony in forum Droid X Apps
    Last Post: 11-24-2010, 06:17 PM
1% cyan battery mod
cyan battery
cyan status bar icons
droid razr battery icon rom tool box
droid razr status bar reset
droid x 1% battery icons
droid x battery icon restore
droid x battery icons
install glowing cyan battery icon
installation aborted on rom toolbox icons
liberty rom battery icon missing 30
razr battery icon
restore droid razr battery icon
rom toolbox icons is not displaying
rom toolbox systemui gtab
