Hey guys, stryker again with another stryker originals. This is my theme called Krush. It’s a theme based on my MIUI theme, Go Launcher, and Apex theme Krush. Now you can get completely Krushed by running this theme in combination with Krush for Go or Apex Launcher for a full experience. I have been working on this theme for a couple months. It has been usable for a while now, but I wanted to make sure I got as much themed as possible b4 release. Plus this is my first Theme Engine theme. So it was defiantly a learning experience, and sometimes a pain in the a** lol. Anyways get Krushed!! Just dont drive. ha.!
***READ BEFORE YOU INSTSALL***
*You must be running ICS with cm9 or aokp with normal gapps. Any other rom that is not cm9 or aokp, you will run into black on black issues. So don't post issues. Or any modified version of aokp or cm9 you will likely run into issues also.
*This theme is for hdpi/xhdpi devices only!!!
*This theme is meant to be ran with normal gapps installed also.
It will still work with inverted gapps, but you may run into some black on black, or white on white issues with text. Just warning you.
WHAT’S THEMED?
Framework
SystemUI
Settings
Phone
Contacts
Camera
Calculator
Play Store
Google Music
Gmail
Rom Control
Stock android keyboard
Swype Beta
MMS
Box
Animated gmail, email, sms, market update, missed call, and alarm notification icons.
Animated pull down handle for JB version
**I will be adding more apps in the future so stay tuned!!
WARNING!!
*DroidXForums and I take no responsibility for anything that might go wrong with your device. Its not our fault!! Read the instructions first before posting any issues.
**Screenshots**
INSTRUCTIONS
**Must be running an ICS Based Rom with T-Mobile Theme Engine support for ics version.
**Must be running a Jelly Bean Based Rom with T-Mobile Theme Engine support for JB version.
1.Go into the theme manager and apply the system theme then reboot.
2. Now go into the theme manager and apply my Krush theme, you will get the “sorry this theme is missing assets for your device screen size pop up”, Hit Apply anyway.
*note, you may get a market force close on install or appling this theme. Just ignore it. It will not affect your phone or the theme.
3. Now Reboot and you should be set!
Download Link
Krush CM9/AOKP Theme
Krush CM10/AOKP JellyBean Theme
**For a complete experience
Download Krush for Go Launcher and Apex Launcher!!!
All in the Play Store.!
**I would like to thank:
*jdcmusicman for all of his help! Get his apex and theme engine themes in the play store. search jdcmusicman.
*The Cyanogen Mod and AOKP Team for there awesome roms and making android better!
*Droid X Forums for being an awesome forum and a home to my themes!
*Anyone who has helped along the way
Problems and Suggestions to: stryker.originals@gmail.com
*YOU SHOULD FOLLOW ME ON TWITTER: sTl2yk3l2
