This started from the Just Red theme I did for Gummy 1.1 ..
I got to porting this over to Theme chooser and well just decided to change a few things.
Somethings are different but one thing is the same ,its still Red
I just published this in the Google Play Store for Free
The name says is all ...Red Rush
Screenshots...
screen_20120707_2300_2.pngscreen_20120707_2258_2.pngscreen_20120628_2050.pngscreen_20120707_2258.pngscreen_20120707_2259.png
I'm sure most all of you know this , but here goes anyways lol...
IMPORTANT!! You MUST be ROOTED and running a ROM that has the CM9 Theme Chooser..
THIS has only been tested on a Droid X running Gummy 1.2 and on a Razr Maxx running Cm9
It May or May Not work good for other roms..Let me know if it does or doesn't , I am willing to try to get it
compatible with other Roms
Hdpi/Xhdpi supported
Link Below
INSTRUCTIONS:
Download , Install Go to settings/themes,Select the System Theme , Reboot ,go to settings/themes,Select Red Rush ,click apply
*NOTE: If you recieve a message saying " Sorry, this theme is missing assets for your device's screen size"
Click Apply Anyway and REBOOT...
There are some things that cannot be themed in Theme Chooser , those things will remain unchanged..
*This is a work in progress ,Everything may not be perfect, I may have overlooked some things
Although I have tried to make sure I have everything right ..
I welcome any Negative or Postive critisim..
But remember this theme is FREE and there is plenty of hours of work involved in making it,and
if you do not think so , try doing it yourself.
If you Like my work ,Support it by buying My matching Red Rush Apex or Red Rush Go Launcher Themes from the Playstore
(these will be ready by the end of the week,Will update post as soon as available)
*Red Rush for Apex is Available now on the Playstore
Free Version https://play.google.com/store/apps/d...pex.theme.free
Paid Version https://play.google.com/store/apps/d...ush.apex.theme
So What's Themed ?
Framework
SystemUI
Settings
Contacts
Dialer
Calculator
Camera
Gmail
Email (somewhat)
Swype beta
Google Playstore
Mms
Stock Keyboard
Dropbox
Root Explorer (somewhat)
Apex (settings icons only) ( I have a matching Apex Theme)
Just a few Icons (I have a matching Apex and Go Launcher theme that will be ready sometime this week)
What's going to be themed next? if possible
Music
Calender
and maybe more ....
Look forward to Purple Rush and Lime Rush very soon
and a very possible Rainbow Rush (going to try anyway)
Special Thanks:
Stryker (for some testing and input) Get his themes for Go Launcher and Apex(available soon) , this man does great work.
Bhuber (for helping a bit when I first got interested in theming )
and whoever else I may have ask questions , I am sure there are more
Google search engine , with out it I would have never learned any of this LOL
Thanks to the Gummy Team for their Great Rom
Thanks to ALL of the Developers that make our Smart phones even Smarter![]()
Thanks to everyone willing to try my theme , considering ,I am still pretty much a newbie themer
Finally the Link :
https://play.google.com/store/apps/d...red.rush.theme
If you like this theme Please give 5 stars and comment Thanks
2Likes
