ShadowMod 12/18
This is a discussion on ShadowMod 12/18 within the Ice Cream Sandwich ROMs forums, part of the Ice Cream Sandwich Development and Hacking category; This is a rom I had posted in the rootzwiki forums that some suggested I post here so without further ado... ShadowMod Beta Screenshot_2012-12-18-23-41-02.png Screenshot_2012-12-18-23-41-22.png ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Like Tree7Likes
Thread: ShadowMod 12/18
    Points: 1,433, Level: 21
    Level completed: 33%, Points required for next Level: 67
    Overall activity: 2.6%
    masterchung89's Avatar
    48538
    Sep 2011
    11
    7 times
    ShadowMod 2/16
    ShadowMod Beta
    Warning: I am by no means responsible if your phone were to die, miss an important call/ text, kill you, etc. Your warranty is already void if you are even looking at this part of the forum.
    About the rom:This is a Cyanogenmod kang based off of X13thangelx's repo. This project initially began during some free time
    Features added to X13thangelx's CM9
    From 12/18 build forward
    Paranoid Android Tablet UI built from latest paranoid android source
    Changes to Paranoid Android native code: fixed leaks, update cm9 base, added wifi timeout, and restart option.
    • rendering tweaks
    • lockscreen vibrate option
    • carrier text
    • fixed usb turning on mobile data
    • cm10 battery options
    • lock screen clock alignment
    • Hwasettings
    • lock screen battery percentage
    • clear all buton to recents
    • selectable gtalk text
    • nav bar options
    • Linaro optimized
    • set tablet navbar to the top
    For 12/9 build
    • More resource friendly system
    • Adjustable navigation bar width and height
    • Option to enable/disable lock screen vibrate
    • Option to enable/disable lock screen rotation
    • Option to enable/disable mms auto retrieval (Cyanogenmod team)
    • User configurable min/max fling velocity
    • Custom boot animation
    • Usb no longer enables mobile data
    Bugs
    Should be the same as the unofficial CM9.I will try to address bugs, but no guarantees.
    Read Thread before posting, no need to clog thread with same question.
    Credits
    Bikerdude880
    X13thangelx (for letting me use is sources)
    Jonman409
    Entire Cyanogenmod Team
    CyanogenDefy (used some of their repos)
    Hascode
    JackpotCalvin
    Google for android source
    rooting community
    Paranoid Android team
    Anyone else that helped in the process
    Install process I would recommend doing a clean install
    • Boot into CWM recovery
    • Wipe
    • Install zip
    • Install gapps
    • Reboot
    Sometimes after flashing boot animation does not show up, wait at least 10 minutes. I would also recommend flashing Wiz's bootmenu.
    ETAs
    DNA: Do Not Ask I will release whenever I think a release is due. Not to sound arrogant but I'm very busy during my senior year on homework especially with college apps.
    Changelog
    3/8
    linaro optimized
    reverted some webkit changes
    option to set tablet navbar to the top
    increased media volume steps to 30 from 15
    2/16
    Fixed per app dpi settings
    2/13
    Nav bar options: height, width, glow time, glow color, button color, alpha
    Selectable gtalk text
    optimization?
    1/20
    Added finishing parts of rendering optimizations (tiles should not show up now)
    1/14
    Bug fixes
    rendering tweaks (scrolling through apps should be smoother)
    12/31
    Fixes on my end
    Fixed am/pm not showing up in tablet mode
    Cm10 battery options
    custom carrier text
    fixed better battery stats being stuck at computing
    some optimization
    faster text clipping
    12/25
    Some optimizations
    HwaSettings (defy)
    lockscreen clock alignment
    12/18 Update
    Starting fresh from a new base, all future builds will be built off from this base
    Paranoid android tablet UI (1.6a)
    (Will integrate mods (things below) in the future)
    12/9 Update
    Improved nav bar response
    Added lockscreen battery percentage
    Added clear all recent apps to recents (CM10)
    Added MIUI battery bar
    Added AOKP battery text (IMO battery than cm9 battery text) (AOKP)
    12/4 Update
    Removed status bar clock in lock screen
    Performance and rendering tweaks (feedback would be helpful as I changed the way the GPU renders)
    IOWaits and disabled process list
    Sped up navbar glow time
    11/23: Initial release
    Download links
    3/8
    http://d-h.st/lZL
    2/16
    Dev-Host - PARANOIDANDROID-pa_shadow-1.6a-16FEB2013-105914.zip - The Ultimate Free File Hosting / File Sharing Service
    2/13
    Dev-Host - PARANOIDANDROID-pa_shadow-1.6a-12FEB2013-200831.zip
    1/20
    Dev-Host - PARANOIDANDROID-pa_shadow-1.6a-19JAN2013-194313.zip
    1/14
    Dev-Host - PARANOIDANDROID-pa_shadow-1.6a-14JAN2013-194357.zip
    12/31
    Dev-Host - PARANOIDANDROID-pa_shadow-1.6a-31DEC2012-165435.zip
    12/25
    Md5:
    fbe354f94bff4f6065972787fe3f7dbe
    Dev-Host - cm-PARANOIDANDROID-12252012.zip
    12/18
    Md5: 3c9bcd6f98d92679efd7e0a65f02c9ec
    Dev-Host - cm-PARANOIDANDROID.zip
    Mirror: http://www.mediafire...u61a4m1gyz081mp
    12/9 (Will be using dev host due to problem downloading by some users)
    Md5: 5D0D42F13D02929E7B120EFD6218C23F
    Dev-Host - cm-9-20121209-UNOFFICIAL-shadow.zip
    12/4
    http://www.mediafire...vmqs2ts7v5e5uq7
    Md5: 2D3DB5F1747A14484AAF66113F511644
    11/23
    http://www.mediafire...4pao2424cyb8jlg
    Md5: 95d3275889883d00da46b493f53a8264
    Gapps
    http://goo-inside.me/gapps/
    For paranoid android builds you must flash these gapps
    http://goo.im/gapps/...0429-signed.zip
    Themer
    Points: 15,649, Level: 80
    jeems's Avatar
    40702
    4,389
    176 times
    Might give this a whirl over the weekend.
    DroidX.xparent.green
    Check out my themes:
    Points: 6,867, Level: 54
    Level completed: 59%, Points required for next Level: 83
    Overall activity: 11.7%
    dtroup64's Avatar
    37346
    570
    18 times
    Flashed last night before bed. Settin it up right this moment. It boots up perfectly, runnin titanium this moment and no issues so far...
    Points: 2,768, Level: 32
    Level completed: 12%, Points required for next Level: 132
    Onethumb's Avatar
    31461
    Iowa
    216
    14 times
    Just flashed and set this up. Very cool rom.
    Sent from my SCH-I535 using Tapatalk 2
    Points: 22,755, Level: 93
    BHuber09's Avatar
    34670
    Atlantis
    6,636
    446 times
    How's this running for anyone on it? I saw it over on rootz a while back, thought about throwing it on my sisters X.
    Tapp'd from one of my Nexus Devices
    FreeMyMoto!!!
    If you need help PM me!!!
    Themer
    Points: 3,997, Level: 40
    Level completed: 24%, Points required for next Level: 153
    jdcmusicman's Avatar
    46668
    Aug 2011
    Earth
    399
    12 times
    Gonna have to give this a try... Time for a change, I've been on Gummy for a while...
    Running Gummy Ics
    Points: 84, Level: 1
    Level completed: 68%, Points required for next Level: 16
    Overall activity: 3.4%
    powerpoint45's Avatar
    63267
    Dec 2012
    10
    Downloading now
    dtroup64's Avatar
    37346
    570
    18 times
    Quote Originally Posted by BHuber09 View Post
    It's running beautifully. Inverted status bar (on bottom) all kinds of configurations you can play with. Runs very smoooooth. Only issue I'm having is when you go into settings, the font is so small it I immediately age 20 years, as I have to slap on a pair of reading glasses to make out the text.
    But I'm lovin' it regardless.
    63267
    Dec 2012
    10
    Quote Originally Posted by dtroup64 View Post
    Check PA settings for larger text (change dpi settings)
cm 10 alpha 3 motorola droid x2.3.4
droid x ice cream sandwich rom
droid x rom shadow icecream sandwhich
pa 1.6 shadow mar droid x
pa shadow 1.6 mar
paranoid android shadow
paranoid shadow 1.6 droid x
paranoidandroid-pa shadow
paranoidandroid-pa shadow-1.6a-16feb2013-105914.zip
reddit cream pies horses 18
