System settings/Display/Sleep
Sent from my Black Iced X
This is a discussion on [ROM] LiquidICS [Unofficial port] within the Ice Cream Sandwich ROMs forums, part of the Ice Cream Sandwich Development and Hacking category; System settings/Display/Sleep Sent from my Black Iced X...
Rooted: 1 Click Droid 3 Method ROM: MIUI 1.9.30 Overclocked 1.3
Why is battery life sucks? I hope jb battery life improves.
Sent from my Xoom using Tapatalk 2
Has anyone had any luck with Bluetooth? Tries to sync it with my car and it wouldn't sync...any thoughts
I'm running miui ics 2.6.29 on my DX. I'm not sure if i has a gingerbread kernel or not. Could i just do a , wipe , data reset , and flash for this rom ? Or would that brick my phone if it has a ics kernel ? thanks
If you're running an ICS ROM you are on the GB kernel. There is no ICS kernel on the X. So yes, just wipe data and cache and flash the ROM and Gapps.
I just installed Liquid today on my Droid X. So far so good, everthing seems to work and I haven't experienced any strange issues. I did do a clean wipe/reset and I have a brand new Class 10 32GB Mini-SDHC card, the original Droid X 16GB card is having a lot of problems.
I also have the same question, where is the original "navigation" app that used to be on the phone originally and can it be downloaded anywhere?
