[ROM] LiquidICS [Unofficial port]
This is a discussion on [ROM] LiquidICS [Unofficial port] within the Ice Cream Sandwich ROMs forums, part of the Ice Cream Sandwich Development and Hacking category; this sounds super promising, i just got back to gb after a llloonggg run on 2nd init froyo liquid. once all works, this may de-throne ...
Page 3 of 26 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 21 to 30 of 255
Like Tree8Likes
Thread: [ROM] LiquidICS [Unofficial port]
  1. #21
    Points: 4,766, Level: 44
    Level completed: 8%, Points required for next Level: 184
    Overall activity: 0.8%
    LiveToPonder's Avatar
    38822
    Long Island, NY....uhhh nope, I live in Seattle now :)
    1,414
    this sounds super promising, i just got back to gb after a llloonggg run on 2nd init froyo liquid. once all works, this may de-throne vtx reloaded
    GS 3izzle but still rollin with the best forum ever...
    Shouts out to Wulf, XJacobX, BKDodger, Peakyboo, Mapatton82, Jersey, Rickw and Popcenator on the assist. It's good to be back!
    http://www.droidxforums.com/forum/gi...bluebread.html
    When VZW doesn't, DX Forums does...
  3. #22
    Points: 9,503, Level: 65
    Level completed: 51%, Points required for next Level: 147
    Overall activity: 99.7%
    clothednblack's Avatar
    51337
    Nov 2011
    Smith river CA
    3,208
    128 times
    Fyi, runs great in a slot with boot manager incase anyone was wondering
    teleported from MI Wizardry UI DXtreme
  4. #23
    Points: 4,203, Level: 41
    Level completed: 27%, Points required for next Level: 147
    Overall activity: 5.6%
    towbiz's Avatar
    41404
    1,095
    23 times
    Quote Originally Posted by clothednblack View Post
    Good to know thanks
  5. #24
    Points: 2,291, Level: 28
    Level completed: 94%, Points required for next Level: 9
    tribals's Avatar
    37767
    125
    Don't do what i did and use droid2bootstrapper to get into recovery after you have Liquid ICS installed....threw me into a bootloop i could not recover from and had to SBF.
    Use the built in recovery.
    My camera works so far on both of my DXs.
    Sent from my Droid Razr Maxx
  6. #25
    Points: 10,092, Level: 67
    Level completed: 11%, Points required for next Level: 358
    Overall activity: 17.3%
    csk415's Avatar
    29658
    North Texas
    1,746
    35 times
    Quote Originally Posted by XxXxX View Post
    Anyone know how to add speed dials, example, when you hold 1 for voice mail, and 2 for the wife, and 3 for the best friend and so on?
    Speed dials don't work on current ICS roms. Think its because all blur has been removed (dialer). I had to set up my favorites within the dialer and use them as a speed dial. Worked pretty good.
    What rom do I run today??
    1kds SBF http://www.droidxforums.com/forum/dr...-problems.html
    If you are in a state of "OMG I jacked my phone up". Go here for help.http://www.droidxforums.com/forum/droid-x-rescue-squad/
  7. #26
    Points: 702, Level: 14
    Level completed: 2%, Points required for next Level: 98
    HowardZ's Avatar
    57043
    Mar 2012
    79
    I installed Liquid today. I didn't like all the time it takes me to set everything up again - though that is not the fault of the ROM of course.
    Initial observations:
    Good: Chrome web browser works, and also Opera Mobile works. These didn't work for me on AOKP, gummy, or CM9 ROMs in the past.
    Bad: Often when trying to put an app on the home screen, the long press will start the app instead of putting the app on the home screen. Also, often if I scroll sideways looking at all the apps something will die.
    Also observed was that it did not come with hijackbootloader which is very useful to boot into clockworksmod recovery. So I had to install it myself.
    Also the additional governers were not installed, so I had to add them.
    In general, it looks like a good ROM, though I there are many functions I have not tried yet.
    Regards,
    Howard
    P.S. Liquid's file size is much smaller than the other ROMs: AOKP, gummy. Also Liquid includes the google apps. Makes me wonder what is missing from Liquid? The file is so much smaller than AOKP + gapps, that something must be missing?
  8. #27
    HowardZ's Avatar
    57043
    Mar 2012
    79
    Ok, I found a major function which does not work: HDMI output.
    The Droid-X has HDMI output, but only for movies played by the Galary.
    However, it does not play all the file types and codec types.
    I have been using a program called Xternal Display which allows HDMI output.
    Along with MX Video player I can play movies on my HDTV.
    However, with Liquid, Xternal Display will not work and this entertainment function will not work.
    Regards,
    Howard
  9. #28
    Points: 1,297, Level: 19
    Level completed: 97%, Points required for next Level: 3
    Overall activity: 1.0%
    V1215's Avatar
    35087
    56
    Quote Originally Posted by HowardZ View Post
    Regards,
    Howard
    I don't believe HDMI works on any 2nd Init ROMs.
  10. #29
    51337
    Nov 2011
    Smith river CA
    3,208
    128 times
    Quote Originally Posted by V1215 View Post
    Works on wizard0f0 miui, video only, audio comes out through the head phone jack
  11. #30
    Points: 3,040, Level: 33
    Level completed: 94%, Points required for next Level: 10
    Overall activity: 2.7%
    XxXxX's Avatar
    5578
    207
    Quote Originally Posted by csk415 View Post
    Cool thanks for the answer.
  1. [ROM] AOKP [unofficial]
    By x13thangelx in forum AOKP
    Last Post: 12-19-2012, 01:14 PM
  2. [ROM] AOKP [Unofficial] 4-17
    Last Post: 04-21-2012, 02:45 PM
  3. [ROM] AOKP [Unofficial] 4-17
    By x13thangelx in forum Ice Cream Sandwich ROMs
  4. [ROM] AOKP [Unofficial] [4/17]
    By HarleyDude in forum Ice Cream Sandwich ROMs
    Last Post: 04-17-2012, 07:52 AM
  5. [rom] aokp b32 [unofficial] [4/11]
    Last Post: 04-17-2012, 02:50 AM
droid x liquid ics
droid x liquid ics 1.6
liquid ics
liquid ics 1.6
liquid ics 1.6 droid x
liquid ics droid x
liquid ics droid x youtube
liquid ics for droid x
liquidics 1.6
mms.ihavegreat.info
