[ROM] LiquidICS [Unofficial port]
This is a discussion on [ROM] LiquidICS [Unofficial port] within the Ice Cream Sandwich ROMs forums, part of the Ice Cream Sandwich Development and Hacking category; No sbf necessary. Just reboot to cwm, do a full wipe, and flash this run. Make sure you back up your apps first....
Page 23 of 26 FirstFirst ... 13 21 22 23 24 25 ... LastLast
Results 221 to 230 of 255
Like Tree8Likes
Thread: [ROM] LiquidICS [Unofficial port]
  1. #221
    Points: 1,507, Level: 22
    Level completed: 7%, Points required for next Level: 93
    steelersnsox's Avatar
    29242
    13
  3. #222
    Points: 878, Level: 15
    Level completed: 78%, Points required for next Level: 22
    clay347's Avatar
    54407
    Jan 2012
    9
    Hey DX FANATIC FIRST AND FORMOST THANKS FOR ALL YOUR HELP BRO BUT NOW MOVING ON TO THE NITTY GRITTY yes I've unzipped the zip and no I'm not at all familiar with rsd lite and also when I try to search it on GPLAY it keeps given me a calculater app by chance do you or some one have a APK I could get from ya THANKS IN ADVANCE BRO the only thing that has happened is this I hit my download app and touch the 15 radio oh and I made sure it's unzipped and takes me into CWM it asked me if I want to back up the rom or wipe cashe and rom I think and a last choice which is what I do which is wipe dalvic and then it starts its process and gets about half way through it then it aborts and then asked me do I want to reboot or shut down I haven't messed anything up YET GLORY AND PRAISE BE TO GOD OUR FATHER IN HEAVEN but Bro any help is greatly appreciated THANK YOU AND GOD BLESS YOU MY BROTHER clay347
  4. #223
    Points: 7,721, Level: 58
    Level completed: 86%, Points required for next Level: 29
    Overall activity: 11.0%
    DroidlynnXDoes's Avatar
    56858
    Mar 2012
    In a world that doesn't
    2,810
    Here is the link to download RSD lite from. You can download it from your computer or phone, but either way it has to go onto your computer because the procedure will be done on your computer. Rsd lite its used to SBF on Windows, if you are on .621 and are SBF'n to stock, then you can only download and use the .621 sbf. This its because previous versions will damage your device. This was because Motorola made it where you cannot revert back to previous versions of Android before .621. If you are trying to root, then you can't use this method. There may be a method avaliable that will allow you to root while on the stock ROM without using the Milestone X SBF, which involves turning your DX into a milestone X which you them have to flash the stock rooted DX rom using CWM. Hope this helps. Sorry for the long post, I just want to ensure that you get enough info to understand how this is done. You wont find RSD in G Play because its a Windows app, not a Droid app.
  5. #224
    56858
    Mar 2012
    2,810
    In order to flash anything on RSD lite, you need, to make your X go into bootloader mode which in order to do so, turn off your X, press home, camera button, volume down, them power, then when you see the boot logo, which is usually MOTO's funny M in a circle, relaese the power button then you will see some white text on a black screen. Make sure it says ok to program and battery ok. I always make sure I have at least 50% of battery before I, use,RSD. After that you then need, to plug in your X to your, computer using the stock MOTO cable, then hit, the button,om RSD, that,has three dots them select the file you want to flash, then tell it, to uncompress and flash, and wait for it to get done. You may have, to do a, factory reset thru your stock recovery to prevent bootlooping after its done flashing. to do so, do a battery,pull,press home and power and release power after the M logo appears and press both volume buttons, them using the volume buttons to scroll up and down, select data wipe, them tell it yes. An SBF or factory reset will not touch anything on your SD card. Before you do this, make sure you make a nandroid backup of your current rom and that you have your, contacts, etc backed up on Google
  6. #225
    clay347's Avatar
    54407
    Jan 2012
    9
    Thanks for the info but I am not on 621 I'm still rocking 605 I never did the update because of being afraid of losing root and all at the time it came out I have a question for you I get OK reception every where except my house but in town and while driving its all good but at my house it's not that great I guess cuz I live in the boon docks lol so my question is if I do the jump from .13 to .15 is it really going to make that much of a difference THANK YOU SO MUCH AND GOD BLESS YOU
    Sent from my Nexus 7 using Droid X Forums
  7. #226
    Points: 3,956, Level: 40
    Level completed: 3%, Points required for next Level: 194
    Overall activity: 3.6%
    milski65's Avatar
    37085
    Orange, Va
    1,010
    15 times
    Quote Originally Posted by clay347 View Post
    I was in the exact same situation as you described. I flashed the 15 radio and it helped at first at my house, but eventually had to go back to using wifi. But you won't really know unless you go ahead and flash it.
    Sent from my DROID BIONIC using Tapatalk 2
  8. #227
    56858
    Mar 2012
    2,810
    I honestly don't know if theres a way to make it faster or not because I also move in the middle of nowhere and my 3G can be slow too
  9. #228
    Points: 4,577, Level: 43
    Level completed: 14%, Points required for next Level: 173
    SupraRZ95's Avatar
    32836
    186
    13 times
    The signal increase is slight. You should get a tad better speed. But I also heard the radio gets best reception with the 621. But 621 is now rootable
    Fart Blood
    68 88 32 45 32 79 67 32 49 46 50 32 103 104 122 32 71 66 32 118 46 48 53 13 10
  10. #229
    Points: 17,911, Level: 85
    Level completed: 13%, Points required for next Level: 439
    Overall activity: 99.8%
    6,225
    138 times
    Quote Originally Posted by SupraRZ95 View Post
    Fart Blood
    621 gets the best signal because of the 15 radio... which you can get without the hassle of 621.
    Sent from my DROID RAZR HD using Droid X Forums
  11. #230
    Points: 2,111, Level: 27
    Overall activity: 2.4%
    wrongitdoo's Avatar
    7205
    USA-CA
    34
    Ack! I tried to restore all my apps using TIBU but for a strange reason it explained I wasn't rooted. Wha?! I see the Superuser availability as it proves I have root access. So, I rebooted into CWM and now I'm stuck on the boot logo. :P I feeling an SBF around the corner.
  1. [ROM] AOKP [unofficial]
    By x13thangelx in forum AOKP
    Last Post: 12-19-2012, 01:14 PM
  2. [ROM] AOKP [Unofficial] 4-17
    Last Post: 04-21-2012, 02:45 PM
  3. [ROM] AOKP [Unofficial] 4-17
    By x13thangelx in forum Ice Cream Sandwich ROMs
  4. [ROM] AOKP [Unofficial] [4/17]
    By HarleyDude in forum Ice Cream Sandwich ROMs
    Last Post: 04-17-2012, 07:52 AM
  5. [rom] aokp b32 [unofficial] [4/11]
    Last Post: 04-17-2012, 02:50 AM
droid x ics
droid x liquid ics
droid x liquid ics 1.6
liquid ics
liquid ics 1.6
liquid ics 1.6 droid x
liquid ics droid x
liquid ics droid x youtube
liquid ics for droid x
mms.ihavegreat.info
