I cleaned the battery, did a calibration, and wiped statistics, we will see how it goes from here.
This is a discussion on [ROM] LiquidICS [Unofficial port] within the Ice Cream Sandwich ROMs forums, part of the Ice Cream Sandwich Development and Hacking category; I cleaned the battery, did a calibration, and wiped statistics, we will see how it goes from here. Sent from my DROIDX using Droid X ...
youtube not working?
Liquid ICS
Search for "You Tube 2.4.4 apk" I ran it and it works good. Disable auto updating.
Anyone having trouble with wifi? After mine has been connected for a while, I can't turn the wifi adapter off and can't connect to any networks.
Which WiFi tether app works?
Liquid ICS
Just out of curiosity, is there any ICS ROM where the camcorder works? I think I already know the answer, but I figured it was worth asking.
None stock but download Videocam Illusion from Gplay. Seems to work on all ICS roms.
Installed the ROM and everything worked perfect. I restored everything with Titanium, rebooted, and now I'm stuck in a bootloop, what do I do?
Did you batch restore with Titanium? If so did that include system data? You shouldn't transfer system data from one rom to another.
Does the Liquid ICS ROM v1.5 have fuse built in or is there a way to easily enable it? I want to be able to connect to my ssh server at home and mount it on the sdcard so music players can access it. I found the app called sshfs android in the market but the fuse prerequisite is holding me back. Any help would be greatly appreciated. I have used linux but know very little and this is the first time I've rooted my phone and installed a custom rom.Does anyone know of another very cool rom for the droid x that does have fuse support?
