fubar'd
This is a discussion on fubar'd within the Ice Cream Sandwich Help forums, part of the Droid X Ice Cream Sandwich Forum category; i was chaning sokme theme elements and now my phone will only show a boot image and then go back to a black screen. i ...
Thread: fubar'd
    fubar'd
    i was chaning sokme theme elements and now my phone will only show a boot image and then go back to a black screen. i have mine set to show a black android on a white screen. if i hold the home key and power at startup my android guy comes up and then fades off the screen in an interlaced style. where do i go from here? i dont have a windoze computer to sbf... maybe necxt week i csn use someone elses...
    Points: 28,222, Level: 98
    Level completed: 88%, Points required for next Level: 128
    7,093
    338 times
    You don't need windows to SBF... you on Mac or Linux?
    Themer
    Points: 15,649, Level: 80
    jeems's Avatar
    40702
    4,389
    176 times
    What cliff said. If you can't get to CWM you are stuck SBFing.
    Check out my themes:
    mac 10.5. if i could fine an iso i'd go to 10.6 or 10.7
    7,093
    338 times
    Depending on your system version you can use the ISO's from this thread: Linux solution to your Windows/RSD lite problems (instructions are listed there.)
    Or you could just download sbf_flash and the file you need from here: https://sites.google.com/site/motosbf/droid-x-sbf-files
    Instructions: Type in the correct sbf file name if you are using a different one.
    1. Make a new directory and download the above files to that directory
    2. Unzip the SBF file into the same folder
    3. Open the folder and keep it open
    4. Open Terminal and change to the folder you created. Easy way to do this is to type CD in terminal, then click and drag the folder to the terminal window and release. Press the enter key.
    5. Next type sh sbf_flash.sh click and drag the SBF file to the terminal window and release. Press the enter key.
    6. Let it run for a bit. There will be a bunch of stuff passing by on the screen. It will eventually say rebooting and return you to a terminal prompt.
    For those of you who are completely new to all this, let me clarify a few things:
    1. when he says make a new directory, he means create a folder (i just called mine droidx) and put the two files in it and remember where the folder is on your mac.
    2. double click the zip file and trash it when it finishes unzipping. now you should have 2 files in your new folder you created: 602.sbf (or whichever sbf you downloaded) and sbf_flash.sh
    3. by "open the folder" he just means keep the finder window in the background so u can easily drag and drop files into the terminal window
    4. just like he said.
    5. here is where the directions aren't clear. it wont work unless you enter a space in between "sh sbf_flash.sh" and "/Users/Pauly/droidx/602.sbf"
    so this works: "sh sbf_flash.sh /Users/Pauly/droidx/602.sbf"
    this doesnt: "sh sbf_flash.sh/Users/Pauly/droidx/602.sbf"
    6. like he said. it takes a while. u should see stuff like this if u did it right:
    === 602.sbf ===
    00: RDL03 0x82000000-0x8204CFFF B942 AP
    01: RDL01 0x00150000-0x001FFFFF DEFA BP
    02: CG03 0x00000000-0x008FCB67 D93E BP
    03: CG31 0xB0280000-0xB02847FF B9A8 AP
    04: CG33 0xB1900000-0xB24C07FF 48DA AP
    05: CG34 0xB0700000-0xB07047FF 75F3 AP
    06: CG35 0xB1000000-0xB13FFFFF B511 AP
    07: CG39 0xB2A00000-0xC41C07FF 4AA7 AP
    08: CG42 0xB0800000-0xB083FFFF AC60 AP
    09: CG47 0xB1400000-0xB18FFFFF 517A AP
    10: CG61 0xB0B00000-0xB0B7FFFF 7BF4 AP
    11: CG64 0xB0000000-0xB00047FF 1768 AP
    12: CG65 0xB0180000-0xB01847FF 7167 AP
    13: CG66 0xD0000000-0xDFFFFFFF C898 AP
    >> waiting for phone: Connected.
    >> uploading RDL03: 100.0%
    -- OK
    >> verifying ramloader
    -- OK
    >> executing ramloader
    -- OK
    >> sending erase
    -- OK
    >> uploading CG31: 100.0%
    -- OK
    >> uploading CG33: 100.0%
    -- OK
    >> uploading CG34: 100.0%
    -- OK
    >> uploading CG35: 100.0%
    -- OK
    >> uploading CG39: 100.0%
    -- OK
    >> uploading CG42: 100.0%
    -- OK
    >> uploading CG47: 100.0%
    -- OK
    >> uploading CG61: 100.0%
    -- OK
    >> uploading CG64: 100.0%
    -- OK
    >> uploading CG65: 100.0%
    -- OK
    >> uploading CG66: 100.0%
    -- OK
    >> verifying CG31
    -- OK
    >> verifying CG33
    -- OK
    >> verifying CG34
    -- OK
    >> verifying CG35
    -- OK
    >> verifying CG39
    -- OK
    >> verifying CG42
    -- OK
    >> verifying CG47
    -- OK
    >> verifying CG61
    -- OK
    >> verifying CG64
    -- OK
    >> verifying CG65
    -- OK
    >> verifying CG66
    -- OK
    >> rebooting
    Thread referenced is here: [How To] SBF to 2.3.340 [MAC OSX] - xda-developers
  1. Fubar'd Droid X
    By insanitylivz in forum Droid X Rescue Squad
    Last Post: 01-15-2012, 12:32 PM
  2. Loaded rubiX ROM, it freaked out, now am i FUBAR?
    By JLonsinger2011 in forum Droid X Rescue Squad
    Last Post: 05-10-2011, 11:58 AM
  3. Fubar
    By heisenberg in forum Hacking Help
    Last Post: 12-07-2010, 10:55 PM
