AOKP stuck in bootloop, can't access clockworkmod recovery
This is a discussion on AOKP stuck in bootloop, can't access clockworkmod recovery within the Ice Cream Sandwich Help forums, part of the Droid X Ice Cream Sandwich Forum category; Yeah, I'm getting even better battery life on AOKP than I did on gingerbread. With email and texting pretty constantly throughout the day, I was ...
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: AOKP stuck in bootloop, can't access clockworkmod recovery
    Yeah, I'm getting even better battery life on AOKP than I did on gingerbread. With email and texting pretty constantly throughout the day, I was only at 50% after 9 hours.
    3 months registered31 days registered250 Experience Points7 days registered100 Experience Points
    nojogray's Avatar
    3383
    Annapolis, Md
    67
    I understand that the app should not be used on these ROMs but does that mean that we don't need a bootstrapper?
    Points: 8,909, Level: 63
    Overall activity: 43.1%
    1,340
    79 times
    I'll try to keep this as short and succinct as possible as I don't feel like writing paragraphs from my phone.
    The "bootstrapper" app is only needed on stock, like post SBF. This is so we can access it initially, and is needed due to out encrypted BL. On unlocked devices you can actually replace stock recovery, would this message isn't needed, but I digress.
    Effectively, the bootstrapper "wraps" the stock recovery so when a recovery request is sent from the UI it boots into that instead. Note this isn't from a cold boot (when coming from off) but on the stock Moto system other safeguards are in place (as outlined in the other thread, such as from a cold boot with USB plugged in) Access is not the same, with the bootstrapper it runs after system init so things still need to get past boot logo to get to CWM.
    Now on a 2nd-init ROM (this is CM, MIUI, any ICS ROM) all of this goes out the window. Instead of recovery being a bootstrap after init, the init process is hijacked and injected with the code of our choice, allowing us to bypass some of the security checks in the encryption and load AOSP. I won't get too much into the details, suffice to say our hijacking method is vastly different, and using Droid 2 Bootstrap on 2nd-init is guaranteed SBF time. Thus, it is needed, on stock to initially get into CWM, but if you're on 2nd-init stay away from it. If you can't access CWM, you broke your recovery or boot procedures somehow. Regardless, if you are looking to avoid an SBF, either learn how to force CWM via ADB from a cold boot or install boot menu with your ROM of choice. CWM via ADB is decidedly old-school, but it is the most reliable, but still requires a PC and requires ADB proficiency. Otherwise boot menu works *most* of the same times as ADB, gives some extra features, and is more n00b friendly. Regardless though SBFs will happen if you are ROMing, as due to our encrypted BL there will be times that no method will save you EXCEPT SBF. One of those times is incidentally by trying to use a bootstrapper on a 2nd-init ROM.
    Edit: still ended up writing paragraphs from the phone.
    tl;dr: droid 2 Bootstrap on stock (and usually safe on stock-based ROMs, although usually unnecessary) don't touch it on 2nd-init ROMs (unless you enjoy SBFing)
    Sent from my SCH-I535
    nojogray's Avatar
    3383
    Annapolis, Md
    67
    Thanks for the help! Sorry I was noobing out.
    1,340
    79 times
    Quote Originally Posted by nojogray View Post
    NP. I'd rather the populace understand the correct answer and know why it's the correct answer. Information is never a bad thing; I was a n00b to at some point, asking DroidXChat why my CWM broke when I used bootstrap, which u til then I had aways been told was "necessary". The locked BL makes things needlessly complicated.
    Points: 4,713, Level: 43
    Overall activity: 1.6%
    newmanx4's Avatar
    34469
    703
    29 times
    Here's what I do. If I have to SBF for any reason, after I root and use Bootstrapper initially, I then uninstall it so I can never touch it again.
    Sent from my Liquid X
  1. Replies: 1
    Last Post: 11-22-2011, 12:24 PM
  2. Stuck in clockworkmod recovery 2.5.0.8
    By mrc00lbreeze in forum Droid X Rooted Issues
    Last Post: 07-30-2011, 09:26 PM
  3. Stuck in Bootloop - Recovery Mode not working
    By lukane77 in forum Droid X Rescue Squad
    Last Post: 05-11-2011, 12:16 AM
  4. stuck in clockworkmod recovery
    By cainethirdmortal in forum Droid X Rooted Issues
    Last Post: 05-05-2011, 07:47 PM
  5. Replies: 1
    Last Post: 10-06-2010, 01:23 PM
aokp boot into recovery
aokp boot loop
aokp recovery
aokp recovery mode
aokp stuck on boot animation
aokp won't boot
aokp wont boot
can't boot into clockworkmod recovery
can't get back into clockworkmod after wiping data and rebooting
