VOIP on ICS
This is a discussion on VOIP on ICS within the Ice Cream Sandwich Help forums, part of the Droid X Ice Cream Sandwich Forum category; So I stumbled upon settings for VOIP and SIP accounts in EncounterICS. I've been a long time user of Sipdroid when on Gingerbread using Google ...
Results 1 to 7 of 7
Thread: VOIP on ICS
    Points: 3,761, Level: 38
    Overall activity: 10.9%
    Mike7143's Avatar
    30987
    Indiana
    947
    18 times
    Arrow VOIP on ICS
    So I stumbled upon settings for VOIP and SIP accounts in EncounterICS. I've been a long time user of Sipdroid when on Gingerbread using Google Talk. Here is how to get your SIP account going.
    Go to dialer.
    Hit the menu button>settings
    At the bottom hit accounts under SIP.
    Add a new account.
    When adding a new SIP account, use the following:
    Username: name-200
    Password: password (same password in the extensions page at pbxes.org which MAY be same password for logging into pbxes.org)
    Server: pbxes.org
    Set as primary account: checked
    That's it. Don't mess with the other settings. Save settings and it should register and be set to go.
    Thanks to Snow02 who helped me get it working!
    Mike7143's Avatar
    30987
    Indiana
    947
    18 times
    I found this guide HERE but I can't seem to get it to work. I have Voice on the phone and am logged in with my dedicated google account for Talk/Voice. Hmm...
    Points: 2,830, Level: 32
    Level completed: 54%, Points required for next Level: 70
    Overall activity: 2.9%
    jun991013's Avatar
    44807
    Jul 2011
    Santa Clara, CA
    404
    Probably cause the mike dosent work.
    Sent from my PD_Novel using Tapatalk
    Mike7143's Avatar
    30987
    Indiana
    947
    18 times
    It should still say it's logged in and ready though. It shouldn't know that the mic is having issues unless you actively try and use it to place a call. Even then, it may still work... I can still place regular phone calls.
    Mike7143's Avatar
    30987
    Indiana
    947
    18 times
    Updated OP with settings. I was able to get it registered and it says receiving calls, however; I can't actually receive any calls. I don't know if that's because there's an error with EncounterICS and the mic or if it's my personal settings that are messed up somewhere else. Perhaps someone else can try and report back!
    Points: 709, Level: 14
    Level completed: 9%, Points required for next Level: 91
    grimloch's Avatar
    31875
    I think Gingerbread has the SIP account settings. I've had it working on my thunderbolt set as follows:
    Username: pbxusername-200
    Password: pbxes pw
    Server: 188.40.65.148
    Authentication username: left blank
    Display name: left blank
    Outbound proxy address: left blank
    Port number: 36999
    Transport type: TCP
    Send keep-alive: Always send
    Keep-alive interval: 119
    Sip User-Agent: left blank
    Used this as a guide: Getting Started - PBXes
    Mike7143's Avatar
    30987
    Indiana
    947
    18 times
    From what I can tell, EncounterICS has working voip but the lack of mic support makes it useless. I can send/receive calls but there's no sound. When I try using Sipdroid that's always worked on GB, it just immediately hangs up on both outgoing/incoming calls.
  1. once again.. DOES VOIP WORK WITH VERIZON DROID X
    By Tdotson in forum Droid X Help
    Last Post: 02-25-2011, 08:41 AM
  2. google voice voip problems
    By dmarth10 in forum Droid X Help
    Last Post: 10-25-2010, 11:42 AM
  3. Google VOIP on phones?
    By sluzbenik in forum Droid X General Discussion
    Last Post: 08-26-2010, 04:31 PM
  4. Looking for a SIP VoIP client
    By Liquidmantis in forum Droid X Apps
    Last Post: 07-16-2010, 02:28 PM
android ice cream sandwich voip
android ics sip
android ics sip account
android ics sip configuration
android ics sip no audio
android ics voip
ice cream sandwich voip setup
ics sip
ics sip android
ics sip client
ics voip
switch sip account ice cream sandwich
voip android ics
voip ics
voip on ice cream sandwich
