Ok gotcha. So if it bootloops do I just restore the nandroid I make for the rom I'm on?
This is a discussion on Help changing roms within the Ice Cream Sandwich Help forums, part of the Droid X Ice Cream Sandwich Forum category; Ok gotcha. So if it bootloops do I just restore the nandroid I make for the rom I'm on? Sent from my DROIDX using Droid ...
if it bootloops... you probably wont be able to get into factory recovery... so from there you'd just sbf reroot then flash the rom you wanna go to
Post Script:
We have nothing to fear but runnig out of beer
don't mind me, I'm just falling
Nemo Aeternamn Wallpapers
Sbf: Linux - Rsd
Common Terminolgy
Root: Ginger
Tether
X2:Q&A+LINKS
Thanks hopefully it doesn't bootloop. Encounterics is awesome but I need my camera and voice input not to mention flash
well if it does, it'll always give yah the chance to make a nandroid of stockGood luck though, hope it all flashes well for you
I bootlooped coming off encounter ics. I did all my wipes too. I did the sbf and all is well!
sent from May's Droid X!!!
I have flashed back and forth between Encounter and CM7 with no issues. Only time I've had to sbf lately has been because of a bad build of CM7.
X
BEST DROIDX SBF METHOD- Linux Boot CD (Thanks 1KDS!)
I had a similar dilemma. .... Last Night I ended up going with the SBF method (using USB). It worked great, just follow instructions closely. .... Got me back to stock gingerbread, then i rooted. Now, the sky is the limit. Good Luck.
Droid X - Running: VorteX RC1
Galaxy Nexus - Running: AOKP B19
Awesome I'm going to sbf tonight thanks
