hi i need help getting ics on my dx never done rooting/flashing before so i would need alot of details and help.
This is a discussion on how to get ics on my DX?? within the Ice Cream Sandwich General Discussion forums, part of the Droid X Ice Cream Sandwich Forum category; hi i need help getting ics on my dx never done rooting/flashing before so i would need alot of details and help....
basics:root with framaroot
i recommend using modified droid x bootstrap
list of ics roms
all in my list
sd_shadow's [Collection] of Links for: Droid X (MB810)
Sent from my XT862 using Tapatalk 2
sd_shadow's [Collection] of Links for: Droid X (MB810) and Droid X2 (MB870)
Always in motion is the future
Forum Guidelines of Conduct
ok i rooted it with framaroot and now i have rom toolbox lite and clockworkmod recovery. what do i do next to get ics
download a rom from here
my list 621 roms
or
Ice Cream Sandwich Development
if you haven't yet Make a Nandroid Backup
then
Put the Rom's .zip on your SD card.
- Use Droid 2 Bootstrap to reboot into recovery again. (Bootstrap Recovery > Reboot Recovery)
- Do a factory reset from within this menu.
- Navigate to "Install zip from SDcard" and select your Rom. Say "yes" to the install and wait for the process to complete.
- Reboot. Congratulations! Your phone should now boot up into the new Rom!
Ok it was a success but lost google play and most of apps
you may need Gaaps, depends on which rom you insalled
