Wifi
This is a discussion on Wifi within the Ice Cream Sandwich General Discussion forums, part of the Droid X Ice Cream Sandwich Forum category; I have just rooted and flashed AOKP's version of Ice Cream Sandwich on my DROIDX. However, the wifi does not work. It will connect but ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Wifi
    Points: 600, Level: 11
    Overall activity: 2.0%
    specter2426's Avatar
    62346
    Oct 2012
    23
    Wifi
    I have just rooted and flashed AOKP's version of Ice Cream Sandwich on my DROIDX. However, the wifi does not work. It will connect but it won't receive any data and I cant tether. Anyone got any suggestions? Would love to have my wifi work again.
    Points: 45,910, Level: 100
    DirtyDroid's Avatar
    28665
    Upstate,NY
    14,576
    384 times
    So is it WiFi issues, or data issues? Or both?
    tap'd from the Gnex
    62346
    Oct 2012
    23
    My 3G data works wonderfully. But as soon as i connect to any Internet anywhere, it just will not load. Wont load the play store. Or the browser. Or sky fire. Or drop box etc. But as soon as i cut it off and move back to 3G, everything is fine.
    Themer
    Points: 15,649, Level: 80
    jeems's Avatar
    40702
    4,389
    176 times
    I know you said "anywhere" but want to clarify. You've tried connecting to several different networks?
    Does it let you enter a password and say that it's connected but it won't load anything or will it not even connect?
    Check out my themes:
    62346
    Oct 2012
    23
    That is exactly correct. I enter the correct password for the correct SSID at several different locations. My house, my dad's house. And my work place. It connects, obtains an IP, and says connected. But nothing.
    Themer
    jeems's Avatar
    40702
    4,389
    176 times
    Has wifi never worked on AOKP? If that's the case you might try reflashing the ROM with a cache wipe. Could be a bad install though I would expect other things to be messed up too.
    A few things to try:
    -Reboot (I know you've probably done this but if not it's the easiest thing to try)
    -Wipe cache in recovery.
    -forget all your wifi connections and then reestablish them
    -you could always try sbf and do a fresh install of aokp over a clean system but that's a last ditch effort.
    62346
    Oct 2012
    23
    The wifi has never worked on AOKP. I have rebooted and wiped cache and forgot my networks haha. Tried all that before posting but those are great suggestions. I was really trying avoid another install. I had Cy's mod for ice cream sandwich but it crashed on me so I tried AOKP'S rom. Should I try going back to Cy's? I liked it better.
    Points: 4,713, Level: 43
    Overall activity: 1.6%
    newmanx4's Avatar
    34469
    703
    29 times
    Wifi always worked fine for me on AOKP. I'd say bad install.
    Sent from my Black Iced X
    Themer
    jeems's Avatar
    40702
    4,389
    176 times
    I prefer AOKP, but don't stay on ICS for very long. I like netflix. You can try just wiping cache and reflashing the rom. Might fix some things and shouldn't wipe data, etc.
    62346
    Oct 2012
    23
    So what's the best way of going about re flashing the rom? I have an iPod and a ps3 for netflix. I could use a semi detailed walk through.
  1. Virtual Wifi - Laptop as Wifi Extender
    By Snow02 in forum Droid X General Discussion
    Last Post: 05-17-2013, 05:11 PM
  2. Replies: 19
    Last Post: 10-18-2011, 07:41 PM
  3. Root WiFi Tether/WiFi 3G HotSpot GB 595
    By evams in forum Gingerbread Development and Hacking
    Last Post: 07-31-2011, 01:45 PM
  4. Is there an app in GB to show what is using Wifi? My WiFi won't turn off in sleep!
    By Coronado is dead in forum Gingerbread General Discussion
    Last Post: 04-11-2011, 04:08 PM
  5. Replies: 1
    Last Post: 10-26-2010, 04:31 PM
download themes for liquid rom 1.52 droid x
droid x ice cream sandwich
droid x ics wifi problem
droid x liquidsmooth rom wifi grey
droidx liquid smooth ics
how to restore wifi connection in ice cream sandwich
is there a droid x rom tha fixes wifi connection
liquid ics looses wifi droid x
wifi on my aokp rom on droid x wont work
wifi password recovery
