Wifi
This is a discussion on Wifi within the Ice Cream Sandwich General Discussion forums, part of the Droid X Ice Cream Sandwich Forum category; Mine is doing the same thing. I have: 1) SBFd .621 using RSD Lite and then rooted using the Magic method (no dice), 2) Flashed ...
Page 4 of 4 FirstFirst ... 234
Results 31 to 39 of 39
Thread: Wifi
  1. #31
    Points: 2,987, Level: 33
    Level completed: 58%, Points required for next Level: 63
    Overall activity: 5.5%
    Toad's Avatar
    54722
    Jan 2012
    Idaho Falls, Idaho
    61
    I have:
    2) Flashed Goose's Wifi Fix (still no dice),
    3) Changed the battery settings, (no luck)
    4) Forgot and re-signed into the network (multiple times throughout the process), still no luck,
    3) Flashed Dubbsy's Liquid ICS with GoogleNow and RAZR Launcher (which by the way is awesome), no dice,
    4) Installed Nandroids that have worked in the past (no dice),
    5) Flashed OA VXLR (another great ROM) multiple times with each (then both) of the Wifi fixes (nothing),...
    Currently I am on Liquid ICS v1.6 (very smooth ICS ROM with nice features and good battery life), however the wifi is still not working at home.
    P.S.: Each time I flashed a ROM I did a mini SBF (Wipe Data/Factory Reset, Wipe Cache, Wipe Dalvik Cache, Format System).
    I am on the 2.6.32.9-g1282440 mcbk83@il93lnxdroid08 #1 Wed Jan 11 12:19:23 CST 2012 Kernal
    I have never had a Wifi problem like this in the two+ years I have owned the X.
    It works at work, at Target, McD's... But not at home. I haven't changed anything at home; and all of my other stuff (laptop, Wii, Kids phones and iPods...) have continued working.
    I have:
    1) Disabled router security,
    2) Changed from b to n, to g, to all,
    3) Changed from TKIP to AES to both
    4) Changed the channel from auto to 11...
    ...and my router firmware is up to date.
    Not sure what to do and would be grateful for some guidance.
    Thanks,
    Toad
  3. #32
    Points: 28,773, Level: 99
    Level completed: 26%, Points required for next Level: 1,227
    Overall activity: 7.4%
    7,093
    338 times
    You listed all possible solutions i could think of... honestly sounds like it may be a hardware problem.
    Could try a bunch of different ROMs and see if it works on any of them.
  4. #33
    Points: 184, Level: 3
    Level completed: 68%, Points required for next Level: 16
    BriCo84's Avatar
    63903
    Jan 2013
    9
    Dont waste your time. I have tried em all. Its not gonna make a difference.
    Sent from my DROID4 using Tapatalk 2
  5. #34
    Tagger Second Class3 months registered100 Experience Points31 days registered7 days registered
    kwest12's Avatar
    57040
    Mar 2012
    30
    In other words, there really isn't a fix for this issue? Ugh.
  6. #35
    Toad's Avatar
    54722
    Jan 2012
    Idaho Falls, Idaho
    61
    Thank You, GoCliffGo, and don't sweat it yet BriCo and kwest; I am working with my ISP.
    I'll post what I learn.
  7. #36
    Toad's Avatar
    54722
    Jan 2012
    Idaho Falls, Idaho
    61
    O.K., it's working again.
    My ISP reset my network. As it turns out, a power surge in my area affected my Wi-Fi box settings.
    After disabling router security, changing from b to n, to g, to all, changing from TKIP to AES to both, and with all of my other stuff (laptop, Wii, Kids phones and iPods...) working, I really didn't suspect the modem.
    Thanks for the responses!
    Sent from my Liquid Iced DROIDX using Droid X Forums
  8. #37
    Points: 51,689, Level: 100
    Overall activity: 99.9%
    fezrock's Avatar
    29044
    Asheville-ish
    10,465
    573 times
    :thumbup:
    Sent from my Galaxy Nexus using Xparent BlueTapatalk 2
  9. #38
    kwest12's Avatar
    57040
    Mar 2012
    30
    Quote Originally Posted by Toad View Post
    Wow... I guess maybe I need to have that done. Thanks for investigating and reporting back!
  10. #39
    Points: 81, Level: 1
    Level completed: 62%, Points required for next Level: 19
    Star01's Avatar
    92485
    Jun 2017
    hello guys ,, todays my wifi isnt working well. i need help how to make my wifi to work well.. )) tanks in advance ..)
  1. Virtual Wifi - Laptop as Wifi Extender
    By Snow02 in forum Droid X General Discussion
    Last Post: 05-17-2013, 05:11 PM
  2. Replies: 19
    Last Post: 10-18-2011, 07:41 PM
  3. Root WiFi Tether/WiFi 3G HotSpot GB 595
    By evams in forum Gingerbread Development and Hacking
    Last Post: 07-31-2011, 01:45 PM
  4. Is there an app in GB to show what is using Wifi? My WiFi won't turn off in sleep!
    By Coronado is dead in forum Gingerbread General Discussion
    Last Post: 04-11-2011, 04:08 PM
  5. Replies: 1
    Last Post: 10-26-2010, 04:31 PM
download themes for liquid rom 1.52 droid x
droid x ice cream sandwich
droid x ics wifi problem
droid x liquidsmooth rom wifi grey
droidx liquid smooth ics
how to restore wifi connection in ice cream sandwich
is there a droid x rom tha fixes wifi connection
liquid ics looses wifi droid x
wifi on my aokp rom on droid x wont work
wifi password recovery
