boot into CWM recovery
do a backup (not necessary, but recommended)
wipe cache
flash the rom .zip file
reboot
Shouldn't mess anything up as far as your data and rom setup is concerned (but there is always a possibility which is why you shuold do the nandroid), but might fix any errors that happened during the initial install.
If this doesn't work, I would probably SBF, but someone else might have some different input if you aren't in a hurry.
