MMS Help
This is a discussion on MMS Help within the Ice Cream Sandwich General Discussion forums, part of the Droid X Ice Cream Sandwich Forum category; I am running cm9 and i have 3g (im on metro) although i cant send/recive pics. I went to the local metropcs store while i ...
Results 1 to 7 of 7
Thread: MMS Help
    Points: 825, Level: 15
    Level completed: 25%, Points required for next Level: 75
    usalaxbro11's Avatar
    59288
    Jun 2012
    41
    MMS Help
    I am running cm9 and i have 3g (im on metro) although i cant send/recive pics. I went to the local metropcs store while i was on the miui v4 rom and they said it wouldnt work because that rom used protocall of some sort so how do i get the mms not 3g apn working for my dx?
    Points: 8,909, Level: 63
    Overall activity: 43.1%
    1,340
    79 times
    Are the MMS apns configured. I know there is various ways to get to the file, I usually just like manually editing with Root Explorer. Its in /system/etc. I've attached a screenshot below of the MMS settings for MetroPCS from my phone. Its a GSIII, so they may be slightly different, but I would expect the MMS server info to be the same. (And probably the rest too)
    Tapped from my jelly-beaned d2vzw
    59288
    Jun 2012
    41
    You have a S3 on metro?
    59288
    Jun 2012
    41
    Wait all that file is, is to tell you what the settings are... so what's a good apn changing app?
    1,340
    79 times
    My s3 is a Verizon. That is the AOSP APN config file though.
    Check the config setting and make sure it exists for Metro PCS. After that you can use the APN Backup and Restore app to implement it. Make sure its installed as a system app when on ICS.
    https://play.google.com/store/apps/d...NBackupRestore
    59288
    Jun 2012
    41
    When I restore to that file it says exception null or something like that
    59288
    Jun 2012
    41
    Late**** but a couple weeks ago, I took my dx t metro and they tried to install the apn... they said the from wouldn't accept them???? Was he lying??????
apn backup and restore exception null
apn settings for metro pcs
cm9 metropcs mms fix
droid x metro 3g
galaxy nexus metropcs mms issue
htc dna apn settings for metro pcs
metro pcs mms settings
metropcs apn settings android
metropcs mms settings
mms settings for metro pcs
