Paranoid android possibility? And/or porting help.
This is a discussion on Paranoid android possibility? And/or porting help. within the Ice Cream Sandwich Development and Hacking forums, part of the Droid X Ice Cream Sandwich Forum category; So the paranoid android made their stuff open source a few months ago and there are a few posts on rootzwiki and xda about porting ...
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 37
Thread: Paranoid android possibility? And/or porting help.
    Points: 6,266, Level: 51
    Level completed: 58%, Points required for next Level: 84
    Overall activity: 5.1%
    Wrapped's Avatar
    27537
    405
    So the paranoid android made their stuff open source a few months ago and there are a few posts on rootzwiki and xda about porting it. It's cm based and the tutorial pretty much said to take a working cm9 release and modify it with stuff from a paranoid android ROM. Sounds easy enough, but I'm sure it's not. Still curious to expand my knowledge though. So is it possible to port Paranoid android to the droid x? If so, read on
    I'm running Ubuntu 12.04, I've got eclipse and android SDK. After I updated to 12.04 the adt plugin stopped working. I think I've got it figured out, just ran out of patience last night.
    So can anyone give me some pointers? What else do I need to give this thing a try?
    Sent from my Nexus 7 using Droid X Forums
    Themer
    Points: 10,971, Level: 69
    Level completed: 31%, Points required for next Level: 279
    Overall activity: 18.1%
    jeems's Avatar
    40702
    3,747
    73 times
    I'm sure it's possible, but I can't really help you. You might make some friends over at XDA who would know this stuff. Good on ya' for trying.
    Check out my themes:
    Points: 18,303, Level: 85
    Level completed: 91%, Points required for next Level: 47
    Overall activity: 95.2%
    6,302
    139 times
    Find csking33 over on XDA. He is the one who did our port. Another active and friendly one is twitish. He ported another ICS ROM over for us.
    Sent from my X2 using DXF
    Wrapped's Avatar
    27537
    405
    Can't get my head around this process... trying to find some guidance, but not much luck there either. My 4 year old really cuts my attention span short too. "Are you gonna look at the computer all day, daddy?!"
    I found a guide on xda, but I'm still a little lost. It says to have a donor and port ROM, where the donor ROM would be CM9 for my phone and the donor ROM would be a paranoid android ics ROM. And then you'd run certain files through a comparison/merge tool. But what I'm confused about is will any ics pa ROM work as long as it's for a device with the same dpi? And which one would I merge too? Donor or port ROM?
    Wish I had the link handy to the guide. But there's a link to it in any Paranoid android ROM thread over at rootzwiki where it says something about wanting to port paranoid android...
    Points: 22,770, Level: 93
    Level completed: 43%, Points required for next Level: 580
    Overall activity: 37.3%
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,667
    134 times
    sounds like you'll want to use cm9/aokp... something like that as the donor rom.. then use paranoid as the port rom...
    because of the certain hardware specifics... i'd assume that you'd need to(or at least it'd be for the best) to use a rom that's already been ported to the dx... for a better mesh
    Post Script:
    Nemo Aeternamn Wallpapers
    Points: 16,388, Level: 82
    Level completed: 8%, Points required for next Level: 462
    Overall activity: 75.4%
    BHuber09's Avatar
    34670
    Atlantis
    5,707
    140 times
    That actually doesn't sound to bad. Nemo expect a gtalk here soon. This made me think of something.
    FreeMyMoto!!!
    If you need help PM me!!!
    Wrapped's Avatar
    27537
    405
    I started dabbling with it. Merged all the stuff in framework-res.apk, but for stuck compiling it with apktool. I think I must have missed something setting it up, because it won't compile it even without making any changes to framework. I just tried decompiling it and then compile it right back, and I still got errors.
    Wrapped's Avatar
    27537
    405
    I get an endless string of this error when I try to recompile the unedited framework-res.
    /usr/local/bin/eeh/framework-res/res/values/public.xml:5909: error: Public symbol drawable/weather_na declared here is not defined./usr/local/bin/eeh/framework-res/res/values-sw600dp/styles.xml:3: error: Error retrieving parent for item: No resource found that matches the given name '@style/Widget.TabWidget'.
    And this one on the edited one.
    Exception in thread "main" brut.androlib.AndrolibException: brut.directory.PathNotExist: apktool.yml at brut.androlib.Androlib.readMetaFile(Androlib.java: 142)
    at brut.androlib.Androlib.build(Androlib.java:159)
    at brut.androlib.Androlib.build(Androlib.java:154)
    at brut.apktool.Main.cmdBuild(Main.java:182)
    at brut.apktool.Main.main(Main.java:67)
    Caused by: brut.directory.PathNotExist: apktool.yml
    at brut.directory.AbstractDirectory.getFileInput(Abst ractDirectory.java:103)
    at brut.androlib.Androlib.readMetaFile(Androlib.java: 138)
    Any ideas?
    37333
    Mo-ab
    7,667
    134 times
    Quote Originally Posted by Wrapped View Post
    Any ideas?
    which version of paranoid are you using? is a a jb build? if so... currently... some apktools have a hard time with jelly bean apps...
    Post Script:
  1. Quick question, is external memory a possibility with DX?
    By 1999nbmZ in forum Droid X Accessories
    Last Post: 08-26-2011, 05:12 PM
  2. Possibility of an update.zip For X2?
    By firefighterguy in forum Droid X2 Hacks
    Last Post: 07-02-2011, 04:38 PM
  3. Any word on a possibility of rooting Android 2.3.3 anytime soon?
    By Astennu Zero in forum Gingerbread Development and Hacking
    Last Post: 06-26-2011, 03:04 AM
  4. Is MIUI a remote possibility?
    By Bajaman in forum Droid X ROMs
    Last Post: 06-13-2011, 07:05 PM
  5. Possibility of an unlocked bootloader? Any thoughts?
    By skennelly in forum Droid X Hacks
    Last Post: 01-13-2011, 10:20 AM
guide porting paranoid android rom
how to port paranoid android 3
how to port paranoid android 3 to any device
how to port paranoid android ics
paranoid android 2. droid x
paranoid android droid x
paranoid android themes atrix
paranoid android xda droidx
port paranoid android ics to any device
possibility and or
