Rooting with Better Terminal Emulator on Droid X, need help
This is a discussion on Rooting with Better Terminal Emulator on Droid X, need help within the Hacking Help forums, part of the Droid X Development category; After installing 2.2 ver 2.3.13 , I erased cache and personal data (shouldn't have I know but the step by step said to do so) ...
Results 1 to 2 of 2
Thread: Rooting with Better Terminal Emulator on Droid X, need help
    Points: 1,342, Level: 20
    Level completed: 43%, Points required for next Level: 58
    JMuldrow's Avatar
    5851
    10
    After installing 2.2 ver 2.3.13, I erased cache and personal data (shouldn't have I know but the step by step said to do so) and lost my root somehow kinda. Easy Root said I was rooted, but most of my root apps except for Drocap didn't work , saying they needed root access. After typing su in Better terminal, it said su permission denied. A buddy of mine gave me the zip Droid2root (said it was the same for Droid 2 and X), he also gave me a link to a SWEET step by step using an emulator and then "force closing" the emulator then going back to it and finishing the typing of the rest of the commands. It worked great until, I did a factory rest to try to fix a minor problem I had with my contacts shortcut force closing on me. Well, after the reset, I lost root again, but I couldn't find the link again either. If anyone knows the link, PLEASE, PLEASE let me know. The title had something like "rooting the lazy or easy way" in it, and again it used an emulator. Even when I try adb shell though my emulator it says:
    /data/data/com.magicandroidapps.bettertermpro/bin/sh:adb: Permission denied
    Thanks guys
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
  1. Rooting the Droid X, as easy as following this.
    By JimMariner in forum Hacking Help
    Last Post: 11-13-2010, 03:34 PM
  2. move files with terminal emulator
    By jlank in forum Droid X Hacks
    Last Post: 08-21-2010, 10:39 AM
  3. Rooting Droid X
    By planetdroid in forum Droid X Help
    Last Post: 08-15-2010, 12:27 PM
  4. How do change shell in droid terminal
    By misdirection in forum Droid X General Discussion
    Last Post: 07-29-2010, 05:25 PM
  5. Someone with the RW/RO terminal commands for X
    By Mike919 in forum Droid X Hacks
    Last Post: 07-23-2010, 09:43 AM
droid x root terminal
droid x root terminal emulator
droid x terminal
how to root droid x using terminal emulator
how to root droid x with terminal emulator
how to root using terminal emulator
root droid x terminal
root droid x terminal emulator
terminal emulator root
