that's because droid x bootstrap is a little outdated.. droid 2 bootstrap works a bit better... but to use x bootstrap... you gotta uncheck usb debugging in settings/applications/development...
This is a discussion on cwm wont boot on zergrush rooted droid x .604 within the Hacking Help forums, part of the Droid X Development category; that's because droid x bootstrap is a little outdated.. droid 2 bootstrap works a bit better... but to use x bootstrap... you gotta uncheck usb ...
Post Script:
Nemo Aeternamn Wallpapers
Or one can use Droid X Bootstrap -> Bootstrap Recovery -> ROM Manager -> UPdate CWM Recovery -> Droid X (2nd-init) -> Reboot into Recovery. Good
The Droid X binaries don't play nice on GB with USB Debugging enabled as mentioned. Swap it to a different binary or disable USB Debugging and should be great. (Even with the Droid X Bootstrap app - just do the bootstrap first the use a different recovery via updating with ROM Manager)
Post Script:
