Can not root my DroidX!
This is a discussion on Can not root my DroidX! within the Hacking Help forums, part of the Droid X Development category; Wait, no it's not. I got rid of the Superuser, but my phone still won't take a root! Please help me out!...
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Can not root my DroidX!
    Points: 42, Level: 1
    Level completed: 84%, Points required for next Level: 8
    Overall activity: 1.5%
    Tagger Second Class
    TheJustBacon's Avatar
    59648
    Jun 2012
    10
    Points: 13,902, Level: 76
    Level completed: 63%, Points required for next Level: 148
    Overall activity: 78.9%
    DroidXFanatic's Avatar
    52093
    Nov 2011
    1,104
    42 times
    Did you burn the ISO file and sbf your X? What did you say your system version was under about phone again?
    Liberty 3V2.0 - DroidX
    Tagger Second Class
    59648
    Jun 2012
    10
    Yes I did.
    And it is 2.3.4
    52093
    Nov 2011
    1,104
    42 times
    That's your android version, what does your system version say as shown on this screenshot.
    Attached Images Attached Images
    Tagger Second Class
    59648
    Jun 2012
    10
    Oh, I imagine it's the same as yours, I accept all the updates. I can't check right now.
    52093
    Nov 2011
    1,104
    42 times
    Quote Originally Posted by TheJustBacon View Post
    That might be the problem, the latest update for Gingerbread system version ending in .621 messed up root and blocked it. There's a way around it but it's more steps and can be a lil confusing.
  8. #17
    Points: 4,713, Level: 43
    Overall activity: 1.6%
    newmanx4's Avatar
    34469
    703
    29 times
    Can you see the system version in About Phone now?
    Sent from my AOKP'd DROID X
  9. #18
    Tagger Second Class
    59648
    Jun 2012
    10
    Yes, and unfortunately that is my system version, I have read up on it, and it seems simple enough. But I have yet to find any cons with it. Is there anything I should know before I continue?
  10. #19
    Points: 3,895, Level: 39
    Level completed: 64%, Points required for next Level: 55
    Overall activity: 0.6%
    ems3's Avatar
    42619
    Jul 2011
    630
    If you are on the .621 update it's possible to root still.... There is a sbf file for the milestone to flash a droid x to .604 from there you can root with zergrush and then you're rooted and can flash roms if you like
    Check out my customized swypes .........http://www.droidxforums.com/forum/dr...keyboards.html
  11. #20
    ems3's Avatar
    42619
    Jul 2011
    630
    Just make sure to check the sbf file and that it will not affect your radio. There's one that is modified just for this purpose. You can burn it to a disc and it will sbf you're phone and the one I used even had the needed root method also.
  1. Ok I'm going root my Droidx
    By Droidxman3g in forum Gingerbread Help
    Last Post: 12-21-2011, 05:01 PM
  2. Simple Droidx root?...
    By AiDub in forum Droid X Help
    Last Post: 03-20-2011, 11:10 PM
  3. Need how to root my droidx
    By Halo in forum Hacking Help
    Last Post: 12-22-2010, 06:47 AM
  4. How to root new droidx
    By dtsig in forum Droid X Help
    Last Post: 11-05-2010, 12:05 PM
droid x superuser not rooted
droid3 and can not root
how do i root my droid x
how doi fix permissionfor my druodx
my droid x will not root
my droid x wont root
root my droid x
rooted my droid x
why can't i root my droid x
why should i root my droid x
