Help! Stuck on Liberty Boot Screen
This is a discussion on Help! Stuck on Liberty Boot Screen within the Hacking Help forums, part of the Droid X Development category; I recently rooted my Droid x. Installed superuser, bootstrap, liberty tool box titanium backup. I backed up my system w/TB. I downloaded the liberty 2.0.1 ...
Results 1 to 7 of 7
Thread: Help! Stuck on Liberty Boot Screen
    Angry Help! Stuck on Liberty Boot Screen
    I recently rooted my Droid x. Installed superuser, bootstrap, liberty tool box titanium backup. I backed up my system w/TB. I downloaded the liberty 2.0.1 rom to my pc and transferred to the sd card. Rebooted in bootstrap recovery. Wiped data/cache, and installed the Liberty rom from the sd card. everything went fine up to that point. The phone rebooted to the Liberty boot screen and just sticks. Left the phone alone for about 20-30 minutes and still stuck. Tried do and a backup restore with TB but phone says no back up found. I ended up using RSD Lite to get the stock system back with the 602.sbf . Tried everything over again. Same thing happens. I don't know if I'm skipping a step somewhere or if I'm just doing it wrong. Phone is still stuck on boot. I did update the phone after the reinstall. Is that what i did wrong?
    Points: 5,945, Level: 49
    Level completed: 98%, Points required for next Level: 5
    Overall activity: 1.9%
    spodoc's Avatar
    17924
    2,043
    88 times
    Liberty 2.0.1 is a froyo rom and you are probably gingerbread. Go to the gingerbread rom section and get liberty 3 2.0 from there. Sbf back to 602, root with Pete's root tools, boot into clockwork and try your liberty 3 2.0 flash.
    Rescue Squad
    Points: 18,090, Level: 85
    Level completed: 48%, Points required for next Level: 260
    Overall activity: 59.8%
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    6,540
    91 times
    Liberty 2.0.1 is meant for 340 on the froyo kernel... And 602 is gingerbread... You want to get liberty 3 v2... is the latest I believe
    "I'll get you my little pretty... and your little dog todo too"
    "I don't even have a little dog todo"
    Post Script:
    We have nothing to fear but runnig out of beer
    don't mind me, I'm just falling
    Nemo Aeternamn Wallpapers
    Sbf: Linux - Rsd
    Common Terminolgy
    Root: Ginger
    Tether
    X2:Q&A+LINKS
    Thanks guess I should have read alittle deeper into it.
    Rescue Squad
    Points: 23,600, Level: 94
    Level completed: 25%, Points required for next Level: 750
    Overall activity: 17.7%
    Leach19m's Avatar
    31277
    Washington
    6,175
    195 times
    No worries carrion, just always remember that the best favor you can do yourself is to make sure you read through the installation instructions throughly. They will always have information on the required system version, and other important info you prevent you from ending up here.
    Its all a learning experience, so just take it as such and you'll be sailing happy in the future.
    Rescue Squad
    Leach19m's Avatar
    31277
    Washington
    6,175
    195 times
    Also if you have questions about what's required or what steps to take, feel free to ask; we are here to help each other.
    spodoc's Avatar
    17924
    2,043
    88 times
    Quote Originally Posted by Leach19m View Post
    Yep, nicest forum on the net
  1. Help, Liberty boot up screen stuck.
    By Jacob Cochran in forum Droid X Rooted Issues
    Last Post: 11-27-2011, 08:05 PM
  2. Replies: 1
    Last Post: 05-26-2011, 06:48 AM
  3. Replies: 0
    Last Post: 04-25-2011, 01:48 PM
  4. Stuck on liberty boot screen?!?
    By dhunter82 in forum Droid X Help
    Last Post: 03-11-2011, 02:02 PM
  5. uh oh stuck on boot screen
    By r1unknown in forum Droid X Help
    Last Post: 10-28-2010, 12:09 AM
downloaded rom stuck on load droid x
droid 3 load screen
droid 3 root is stuck boot up
droid 3 root stuck at boot screen
droid 3 stuck on boot screen
droid x boot screen stuck
droid x liberty 3 rom stuck boot screen
droid x liberty 3 v2 stuck at boot screen
droid x liberty reboot
droid x liberty rom screen
droidx stuck in boot screen
i have a boot screen on my droid x
liberty rom droid x reboot
liberty rom stuck on boot screen
liberty rom stuck on boot screen droid x
