Fix: Rooted and moved su to xbin, lost root with Froyo? Fix here.
This is a discussion on Fix: Rooted and moved su to xbin, lost root with Froyo? Fix here. within the Hacking Help forums, part of the Droid X Development category; Saw this in another thread, it came in handy for me. Originally posted on AllDroid, reposted here by someone else. Originally Posted by AllDroid.org Forums ...
Results 1 to 10 of 10
  • 1 Post By rafarquhar
Thread: Fix: Rooted and moved su to xbin, lost root with Froyo? Fix here.
    Points: 1,153, Level: 18
    Level completed: 53%, Points required for next Level: 47
    rafarquhar's Avatar
    891
    38
    Quote Originally Posted by AllDroid.org Forums
    If you have /system/xbin/su and /system/app/Superuser.apk, but cannot use "Superuser" (no prompts from Superuser app, "permission denied" when you try to run "su"), just do the following:
    Run "adb shell"
    Run "/system/xbin/su"
    Watch your screen for Superuser app to prompt for permission and click "allow"
    Run "mount -o remount,rw /dev/block/system /system"
    Run "cp /system/xbin/su /system/bin/su"
    Run "chmod 4755 /system/bin/su"
    [optional] Run "mount -o remount,ro /dev/block/system /system"
    This seems to be a fairly common problem.
    Jaxidian likes this.
    BlinkSS's Avatar
    4365
    Delaware
    29
    But what if you didn't move su to xbin? I didn't move any files previous to update and lost my root.
    Points: 2,799, Level: 32
    Level completed: 33%, Points required for next Level: 101
    250 Experience PointsThree FriendsCreated Album picturesYour first Group100 Experience Points
    Calendar Award
    yurdle's Avatar
    78
    In a land with pretty pink elephants =) Oh wait.. do people see this?
    513
    25 times
    Quote Originally Posted by BlinkSS View Post
    I think the only way to do this is to SBF and start over
    Droid X
    Gingerbread
    Stock - Rooted - Deodexed
    Xoom(Gold Oscar Edition)
    Honeycomb 3.1
    Stock
    BlinkSS's Avatar
    4365
    Delaware
    29
    Alright just did. Where do these commands get typed into? Command Prompt with DX connected via USB?
    Calendar Award
    yurdle's Avatar
    78
    513
    25 times
    Hoping my PM helped here.. I'll post what i said here also in case anyone else needs help
    Droid X
    Gingerbread
    Honeycomb 3.1
    Stock
    X Pursuant Achievements:
    Jaxidian's Avatar
    47
    Indianapolis
    694
    48 times
    OMG, this fixed my problem! Apparently in my situation, rather than moving su from bin to xbin, I copied su from bin to xbin and that caused my problems. Silly me! This worked perfectly for me and I now have root again, and on FroYo without having to revert back to SBF and reupgrading! Thanks so much! I stumbled across then as I was trying to find help on applying the SBF to try again - you saved me a system wipe, which I definitely appreciate!
    Calendar Award
    yurdle's Avatar
    78
    513
    25 times
    Lol lucky you =p I put the su file in the wrong folder when rooting on my girlfriends so thats where i went wrong... so just need to find an app to back up her app data without needing root.... i can at least get her user app data.. no system app data... or i can wait for froyo root... she doesn't need root despritely .. so might just do that.
    Droid X
    Gingerbread
    Honeycomb 3.1
    Stock
    Xaero's Avatar
    6980
    Anyone working on a hack ti get root on 2.2 directly? I doing want ti have to sbf and wipe everything
    Jaxidian's Avatar
    47
    Indianapolis
    694
    48 times
    Quote Originally Posted by Xaero View Post
    I'm sure some people are, but I doubt it's an insanely high priority right now like it was for 2.1. Give it some time and there will be something, I bet...
    Points: 884, Level: 15
    Level completed: 84%, Points required for next Level: 16
    moosc's Avatar
    6144
    7
    ok first what or how are u connecting your X to the computer? which mode? the only way i can connect with debugging staying on is with usb mass storage mode clicked not pc mode? any one else have this? also after adb shell next step i keep permission denied..
  1. Replies: 39
    Last Post: 08-20-2010, 12:30 PM
  2. lost root
    By newinfl80 in forum Droid X Hacks
    Last Post: 08-15-2010, 12:02 AM
  3. Replies: 2
    Last Post: 08-06-2010, 09:05 AM
  4. Lost Root
    By opiekelly in forum Droid X Hacks
    Last Post: 07-29-2010, 01:28 PM
  5. Replies: 0
    Last Post: 07-27-2010, 10:25 PM
%2fsystem%2fxbin%2fsu
/system/xbin.su
/system/xbin/su
/system/xbin: permission denied openvpn
adb shell : su permision deined fix
chown root:root system/xbin/su
droid x lost root
droid x root fix
droid x update lost root
lost root droid x
lost root on droid x
sistem xbin su
system xbin su
system xbin su permission denied
system%2fxbin%2fsu
system+xbin su
system/xbin
system/xbin/su
xbin su
xbin/u
