I just upgraded from 2.2.1 to 2.3.4 and want a new rom....I SBFed did a backup with bootstrap, then went to mounts and storage, mounted and then put Apex on and it wont stop looping , stuck in apex splash screen
This is a discussion on Help please 2 days and still no rom within the Hacking Help forums, part of the Droid X Development category; I just upgraded from 2.2.1 to 2.3.4 and want a new rom....I SBFed did a backup with bootstrap, then went to mounts and storage, mounted ...
Did you wipe data and cache and dalvik? Why did you mount, I dont recall apex telling you to do that.
Running with MIUI
Droid X powered by MIUI or whatever rom is new and booting off of Boot Manager
I've got my SBF badge.
No I didnt wipe cache or dalvik...I mounted because it did the same thing before when I didnt mount last night
I cant get into Bootstrap now, Do I have to SBF again?
Good Morning theothor...
Not sure which Apex your flashing...Yes, SBF back to .602.605...Follow the OP instructions with Apex and you should have any issues...
You're missing some steps my friend...As Silver said, not sure why your mounting...Unless you have a Horse...Kidding...
Apex ROM is Awesome...Read thru it first...Understand what its asking to do...any questions before you Flash throw it out to this Awesome Forum...
All these Guys/Gals are Incrediable on the Forum for Resolve...
You can do It...
Good Luck see you soon on Apex...
Its Bubba
It'sGoing Along for the Ride...
"Stubborn In You're Bones"
Thanks bud, I appreciate the help, Ill get back to ya soon
Is this an X or an X2? If you're on 2.3.3, you only need to mount anything if you're on Froyo (2.2.1) and using the AIO installer, which can only be used from Froyo. You'll want the other zip Fab has posted in the thread and do your normal wipes (data, cache, dalvik cache).
Need more help? Click above ^
X SBF Instructions
X2 SBF Instructions
.602/.605 Root
Android Dictionary
Froyo to Gingerbread
