I,ve run super charger script off and on for months, but now with all the updates to script manager app, I can't get it to work. has anypne elsehad this problem?
This is a discussion on super charger script within the Hacking Help forums, part of the Droid X Development category; I,ve run super charger script off and on for months, but now with all the updates to script manager app, I can't get it to ...
What is happening? Are you checking the little SU icon before you run it?
on the move..
Need more help? Click above ^
X SBF Instructions
X2 SBF Instructions
.602/.605 Root
Android Dictionary
Froyo to Gingerbread
