Help! Need to unroot and sbf asap!
Hey guys... I need help, I rooted my phone about 9 months ago and put liberty on it... It constantly force closed apps and froze my phone so I removed it (i guess). So now my mom is geting my phone because I an getting a new one but it still makes me choose to boot my phone when I first turn it on and it still shows the liberty boot thing when I turn it on... Please help I an such a noob!
12-26-2011 01:22 AM
If you need to SBF just follow this link and follow the instructions there. You'll be good to go in no time
Thank you so much... Will that remove the recovery thing my phone goes into when I first turn it on ?
Yup, it totally wipes your phone (minus the SD Card) and replaces the system with the stock, fresh out of the box, official version of android; removing anything you've done to change it in the process.
Thank you!
Ok... I sbf'd my phone and it was successful but i still have all my apps and stuff... Is that normal? I also have superuser...
Originally Posted by
NMC
Are your apps on your SD by chance? If the sbf took ...your phone should be stock
Can an sbf be done if the phone is deactivated?
Sent from DroidX running Vortex RC1.
mrkasparks
Yes it can... As long as the phone can boot into bootloader mode... You should be able to
