How do i update cwm to 5.0.2.0?
I am running liberty v2.0.1 and would like to update to the new version of clockworkmod. Can somebody give me the step-by-step directions to do so. Once i download the new version from rom manager do i use "droid 2 bootstrapper" to get the update to work? Any and all help would be great.
Thank you for your time and assistance!
-droidx_46
12-24-2011 08:54 PM
sounds like you've pretty much got it... all you do is select recovery... you can use droid x or droid 2... do not use droid x(2nd init)
so all you'll want to do is go into boot strap... select bootstrap recovery... then go into rom manager.. click flash clock work recovery.. i'd just use droid 2 recovery on the version of liberty your on...
then just click reboot recovery from rom manager....
