Stuck on Motorola screen after flashing the latest miui.....need help.....
This is a discussion on Stuck on Motorola screen after flashing the latest miui.....need help..... within the Hacking Help forums, part of the Droid X Development category; hi yall, im on GB but i forget what version and i can't check because my phone is stuck on the motorola screen.... yesterday I ...
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Stuck on Motorola screen after flashing the latest miui.....need help.....
    hi yall,
    yesterday I was trying to flash the latest miui rom (1.10.21) and something went wrong due to my carelessness...
    when i tried rebooting after flashing, i was stuck on the motorola screen.....
    i took the battery out and let it load, but again it goes back to being stuck to the motorola screen but this time the led flashes blue, then to green after a second or so.
    so i was like, oh geez, no problem! i took the battery out, put it back, and held the home button and power button until it takes you to the screen where the triangle exclamation mark and the little green android guy is hanging out.
    i hit the search button and wiped data/factory reset, wiped cache, and rebooted. but then again, it does the same thing.
    any ideas?
    thanks guys
    Banned
    Points: 6,358, Level: 52
    Level completed: 4%, Points required for next Level: 192
    Overall activity: 59.1%
    500 Experience Points250 Experience PointsThree Friends100 Experience Points7 days registered
    cobracon71's Avatar
    24256
    chester,va
    1,445
    113 times
    when you see the light turn blue press volume down that will take you to recovery
    try wiping data and cache and see if it will boot up
    if not i hope you made a nandroid backup
    Most Creative Screenshot
    Points: 8,944, Level: 63
    Level completed: 65%, Points required for next Level: 106
    silver04v's Avatar
    26597
    New Hampshire
    1,492
    36 times
    Quote Originally Posted by cobracon71 View Post
    Do this, but if you can get into the clockworkmod when the blue led flashes, then re flash the rom if you dont have a backup. Unless the reason it messed up was because the file was bad?
    Droid X powered by ICS
    I've got my SBF badge.
    Points: 29,424, Level: 99
    Nemo aeternamn's Avatar
    37333
    Mo-ab
    7,738
    165 times
    and when the android dude pops up... and your on gingerbread(which is why the search key wouldn't work... you'll want to press both volume buttons instead.....
    and instead of the camera button to select.... you gotta press the power button
    Post Script:
    Nemo Aeternamn Wallpapers
    Banned
    cobracon71's Avatar
    24256
    chester,va
    1,445
    113 times
    wow im sure that will confuse him because it did me lol
    37333
    Mo-ab
    7,738
    165 times
    Which part was confusing cobra and I'll clarify
    Post Script:
    Banned
    cobracon71's Avatar
    24256
    chester,va
    1,445
    113 times
    well i think we was "i know i was" referring to the miui recovery not stock
    37333
    Mo-ab
    7,738
    165 times
    I know you were cobra... But at the end of the op he stated how he couldn't get into stock recovery... So I's just letting him know how to get into stock recovery in gingerbread
    Post Script:
    Themer
    Points: 4,766, Level: 44
    Level completed: 8%, Points required for next Level: 184
    nemosfate's Avatar
    27305
    cincinnati
    1,080
    20 times
    Quote Originally Posted by falconmang View Post
    any ideas?
    thanks guys
    He said he did factory wipes
    And rebooted... And still got stuck...
    So I don't think that will help anything regardless of which recovery..
    Maybe sbf is needed
    Root, Roms and Themes, oh my...
    Points: 6,372, Level: 52
    Level completed: 11%, Points required for next Level: 178
    savagerun's Avatar
    41501
    2,204
    54 times
    I was confused when the op said he was on GB and pressed the search button and got in recovery to wipe. That's not even possible.
  1. stuck on motorola screen
    By sallanm in forum Droid X Rooted Issues
    Last Post: 10-30-2011, 12:11 PM
  2. Stuck at Motorola boot screen
    By xkush in forum Droid X Rooted Issues
    Last Post: 04-10-2011, 02:03 AM
  3. stuck on opening black motorola screen, green led is flashing
    By gm54 in forum Droid X General Discussion
    Last Post: 09-23-2010, 08:12 PM
  4. Stuck on Motorola screen...
    By xDROID in forum Droid X General Discussion
    Last Post: 09-19-2010, 05:47 PM
  5. Stuck on Motorola screen...
    By xDROID in forum Droid X Help
    Last Post: 09-08-2010, 11:12 PM
atrix stuck at motorola logo
atrix stuck in reboot
blinking screen on galaxy s2
droid x freezes on motorola logo
droid x frozen on motorola logo
droid x hangs at motorola screen
droidx stuck on motorola after rom
flashing motorola screen
motorola atrix stuck at boot screen
motorola droid x frozen motorola logo
