Bootstrap Question
This is a discussion on Bootstrap Question within the Hacking Help forums, part of the Droid X Development category; Hi this is my first post here and I just have a quick question regarding bootstrap. I'm currently running LGB v0.8, and I have a ...
Results 1 to 10 of 15
Thread: Bootstrap Question
    Points: 561, Level: 11
    Level completed: 22%, Points required for next Level: 39
    3 months registered100 Experience Points31 days registered7 days registeredTagger Second Class
    TheBananaPeel's Avatar
    42847
    Jul 2011
    18
    Bootstrap Question
    I'm currently running LGB v0.8, and I have a backup made from the rooted version of gingerbread. Could I recover back to that version with no problems, and if I did that, could I then recover back to the LGB?
    Also I'm eventually going to use Maderstock340.zip, and once I use that and make a backup of that can I keep just using the backup of that instead of keep having to flash Maderstock each time, and can I go from Maderstock back to gingerbread or LGB by using a backup?
    Thanks a ton and sorry about all the questions, like I said, I'm new to all of this!
    Points: 6,060, Level: 50
    Level completed: 55%, Points required for next Level: 90
    Overall activity: 0.8%
    LiveToPonder's Avatar
    38822
    Long Island, NY....uhhh nope, I live in Seattle now :)
    1,414
    Quote Originally Posted by TheBananaPeel View Post
    Hey man, I wouldnt do anything until a Moderator or Rescue squad member chimes in here, but I can offer ya at least a reply. If you have a nandroid of .596 Rooted, you need to reflash .596 before restoring that nandroid, my understanding is that nandroids ought only be flashed over matching builds. This is also best done after a data/cache/davlick cache wipe in Clockwork (or Bootstrap) if you will.
    Secondly, I dont see a blessing given too often around here to .340maderstock options, 1KDS Live Disc is the preferred method back to Froyo. Anyway, as I stated before do nothing without hearing from an authority figure, but I believe my info is good thus far. Welcome man, youre in the right hands, best Support Forum Community ever.
    GS 3izzle but still rollin with the best forum ever...
    Shouts out to Wulf, XJacobX, BKDodger, Peakyboo, Mapatton82, Jersey, Rickw and Popcenator on the assist. It's good to be back!
    http://www.droidxforums.com/forum/gi...bluebread.html
    When VZW doesn't, DX Forums does...
    Points: 9,994, Level: 66
    Overall activity: 1.2%
    TideFan22's Avatar
    23940
    Florence,Alabama
    3,097
    64 times
    On the first question u can restore a backup of stock rooted GB, and vice versa just don't try to restore a 340 backup. Just gingerbread. And on the second don't use maderstcok on GB, I would either use the rsd lite way or 1kds way
    From my Simply Stunning X
    TideFan22's Avatar
    23940
    Florence,Alabama
    3,097
    64 times
    Do u mean if your on liberty and want to go back to stock rooted GB and vice-versa, via a backup?
    38822
    1,414
    Quote Originally Posted by TideFan22 View Post
    On the first question u can restore a backup of stock rooted GB, and vice versa just don't try to restore a 340 backup. Just gingerbread. And on the second don't use maderstcok on GB, I would either use the red way or 1kds way
    Ya see, support is always just a minute away;-) Tide is Liberty that similar to .596 that nandroids can be flashed over Liberty installs? Def not arguing, just curious? Does that mean no wipes either?
    TideFan22's Avatar
    23940
    Florence,Alabama
    3,097
    64 times
    If hes meaning that if he's on LGB and wants to restore a backup back to stock rooted GB. Yes he can restore back...
    38822
    1,414
    Thats what I got from it, on Liberty but has a nandroid of .596 w/root. I'd just figured hed have to flash .596 again before flashing a nandroid, I have never used Liberty, is their alot of .596 in there? I guess so if you could drop a Blur nandroid on it
    TideFan22's Avatar
    23940
    Florence,Alabama
    3,097
    64 times
    Yeah he can restore that backup, nothings gonna be carrying over, he can restore any GB backup,
    Points: 2,189, Level: 28
    Level completed: 26%, Points required for next Level: 111
    Overall activity: 4.7%
    fnmetal's Avatar
    35394
    new haven CT
    668
    15 times
    Nandroids should restore as long as they're based on the same system version, lgb 0.8 is based on 4.5.596, so. The system versions are the same, so theoretically the restore should work to stock rooted 4.5.596.
    38822
    1,414
    Cool man, thanks, that's why I never reply without advising people to wait some Brass to show up, learned something new.
  1. Bootstrap Question
    By Jhardy in forum Droid X Hacks
    Last Post: 02-18-2011, 07:57 PM
  2. Bootstrap Question
    By mkoop in forum Droid X Hacks
    Last Post: 01-10-2011, 04:00 PM
  3. Bootstrap question
    By Koopa Troopa in forum Droid X Hacks
    Last Post: 01-07-2011, 01:06 PM
  4. Question about using bootstrap.
    By Mudig in forum Droid X Hacks
    Last Post: 12-21-2010, 03:41 AM
  5. Bootstrap QUESTION....
    By newdroidx in forum Droid X General Discussion
    Last Post: 09-14-2010, 10:15 PM
bootsrap question
bootstrap android please expalin
bootstrap http://www.droidxforums.com/
download lgb bootstrap
install lgb bootstrap
lgb bootstrap
lgb bootstrap 605
lgb bootstrap download
lgb bootstrap droid x
lgb bootstrap recovery download
lgb droid x bootstrap
turbocharger bootstrapping definition
where to download lgb bootstrap
