Going from GB Leak to Liberty process...
This is a discussion on Going from GB Leak to Liberty process... within the Hacking Help forums, part of the Droid X Development category; I am currently running the GingerAle Rom from the GB leak. I noticed a decrease in battery and I would love to give Liberty 2.0 ...
Results 1 to 1 of 1
Thread: Going from GB Leak to Liberty process...
    Tagger Second Class
    Buckeye3's Avatar
    39631
    I am currently running the GingerAle Rom from the GB leak. I noticed a decrease in battery and I would love to give Liberty 2.0 a run for how good it seems to be for all DX users. I understand I need to SBF in order to then re-root and flash Liberty to my phone. I noticed on the SBF files that anyone coming from the GB leak must use the newest SBF file which seems to be the Android 2.2.1 System Version 2.3.340 Full (VRZ_MB810_2.3.34_1FF_01) (Current OTA). I thought that in order to go into Liberty I would need to be on (the_gift2). If anyone has done so or has knowledge on what should properly be done let me know.
    Thanks!
  1. Questions about the OTA process
    By xjeepguy in forum Droid X Help
    Last Post: 04-08-2011, 01:10 PM
  2. Liberty 1.5 email process error and sysctl config
    By usmc7356 in forum Droid X ROMs
    Last Post: 02-04-2011, 01:00 AM
  3. Rubix focused 1.9.0 for leak and non leak versions out1
    By theidoctor in forum Droid X ROMs
    Last Post: 12-07-2010, 10:36 AM
  4. Replies: 7
    Last Post: 11-18-2010, 04:11 PM
  5. Gps toggle process
    By iDr0id in forum Off-Topic Discussion
    Last Post: 08-23-2010, 01:26 PM
droid x rom gingerale
flash liberty to vrz mb810 2.3.34 1ff 01
ginger ale rom droid x
gingr ale rom
liberty sbf file
