Super user won't recognize Terminal Emulator
This is a discussion on Super user won't recognize Terminal Emulator within the Hacking Help forums, part of the Droid X Development category; Thank you very much. It's been driving me nuts that everytime I reboot my phone it goes to clockwork and I have to hit "reboot ...
Results 11 to 20 of 23
Thread: Super user won't recognize Terminal Emulator
    Transformed's Avatar
    9975
    Indianapolis , IN
    44
    It's been driving me nuts that everytime I reboot my phone it goes to clockwork and I have to hit "reboot system" for it to start up.
    Since I have to reboot frequently for the phone to function correctly it gets old.
    Once if I can figure out how to get rid of Clockwork I'm taking it to Verizon. Which is why I want to eliminate root but I'm more afraid of SBF it.
    Points: 19,500, Level: 88
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    Yup, no problem...good luck with it
    9975
    Indianapolis , IN
    44
    In case you'd like to answer another question.
    It took what you told me but when I try the rm/system/bin/logwrapper line it says unknown.
    In that link it's for bootstrapper not clockwork is the removal the same?
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    Quote Originally Posted by Transformed View Post
    Yeah...that's how to remove bootstrap and clockwork recovery. Bootstrap installs clockwork, so it's the same...
    You're following these instructions below exactly?
    UNINSTALL the Recovery APK (Droid X Bootstrapper) in Settings, Applications
    Reboot
    Run "su"
    Run "mount -o remount,rw /dev/block/mmcblk1p21 /system"
    Run "cp /system/bin/logwrapper.bin /system/bin/logwrapper"
    Reboot
    9975
    Indianapolis , IN
    44
    I was following the instructions for clockwork removal off of roolers page and it is different than that. It has a few more lines.
    9975
    Indianapolis , IN
    44
    Okay I followed that exactly and after the last line it says "logwrapper not found".
  8. #17
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    Okay, did you uninstall the bootstrap app first?
    If you continue to have issues, I would suggest a sbf to wipe everything clean, rather than do it manually. A sbf is nothing to be scared of, as long as you have a well charged battery. Let us know, and we can help if you want to go that route. This is a really easy method...SBF live disc
    Honestly, unless it works right away, it's just not worth spending hours to try to do the manual way when you can wipe it clean in 10-15 minutes.
  9. #18
    9975
    Indianapolis , IN
    44
    I don't have the bootstrapper on my phone.
    I uninstalled bootstrapper and unrooted like 3 weeks ago. Forgot to uninstall clockwork and it's been bugging me so I reinstalled Z4 just to get rid of clockwork.
    I went through my settings>applications and did not see bootstrapper so it's not on my phone.
    Can't I use the wipe data option on clockwork to return it to stock?
    Jailbreaking my iphone was so.much simpler. Haha.
  10. #19
    9975
    Indianapolis , IN
    44
    Looking at that SBF link there is no way I would attempt that. I also don't have the internet at home I do everything on my phone since I just moved so downloading big files would be a pain.
    I know you're thinking I shouldn't have messed with it in the first place, it's okay. I feel that same way right now. Kind of want to run it over with my truck and take it to Verizon and use my insurance on it. Haha.
  11. #20
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,140
    200 times
    Alright, then do this...reinstall bootstrapper, open it and select "bootstrap recovery", then "reboot recovery". When it boots, select reboot now. Then uninstall bootstrap and try the instructions I gave again.
    Sent from my X to the interwebz
  1. Gingerbread and terminal emulator
    By WillMiii in forum Gingerbread General Discussion
    Last Post: 04-06-2011, 10:03 PM
  2. Terminal Emulator
    By drakeeeeeeee in forum Droid X Apps
    Last Post: 03-19-2011, 04:18 PM
  3. Need some help with terminal emulator
    By xjacobx in forum Droid X Hacks
    Last Post: 01-10-2011, 05:40 PM
  4. Terminal emulator
    By jeffstoic in forum Droid X Hacks
    Last Post: 12-20-2010, 04:46 PM
  5. Replies: 1
    Last Post: 09-16-2010, 06:51 AM
android superuser terminal
android terminal emulator su not found
android terminal emulator superuser
android terminal su not found
android terminal superuser
su not found terminal emulator
terminal emulator android su not found
terminal emulator android superuser
