stuck on boot loader
This is a discussion on stuck on boot loader within the Hacking Help forums, part of the Droid X Development category; i downloaded the full instal version on GB from liberty and tried to install it. everything went as planned, but it is stuck at the ...
Thread: stuck on boot loader
    Points: 1,393, Level: 20
    Level completed: 93%, Points required for next Level: 7
    Jeffer13's Avatar
    35464
    Syracuse, New York
    146
    i downloaded the full instal version on GB from liberty and tried to install it. everything went as planned, but it is stuck at the bootloader screen. please help
    Points: 67,578, Level: 100
    Overall activity: 16.2%
    HarleyDude's Avatar
    19213
    Philly area
    8,191
    460 times
    First try a battery pull, see if that helps.
    Second would be to go into recovery and do a data/cache wipe, that should fix it.
    If not, then SBF is in order
    Jeffer13's Avatar
    35464
    Syracuse, New York
    146
    well i cant get to the factory reset so i cant wipe everything. and i used a program on my sd card to sbf
  1. Using Boot loader
    By luckystreak in forum Droid X Hacks
    Last Post: 02-12-2011, 11:28 AM
  2. start up into boot loader?
    By shawn in forum Droid X Hacks
    Last Post: 02-06-2011, 08:51 PM
  3. Boot Loader
    By IFeelYourPain in forum Droid X Rescue Squad
    Last Post: 01-15-2011, 04:12 AM
  4. Stuck in boot loader
    By crysisanity in forum Droid X Help
    Last Post: 10-05-2010, 12:35 PM
  5. easy boot loader access..
    By RnD_Solo in forum Droid X General Discussion
    Last Post: 08-29-2010, 07:11 PM
cant get into recovery droidx stuck on liberty bootloader
droid stuck in bootloader with sd card in
droid x shows bootloader
droid x stuck liberty bootloader
liberty bootloader
liberty stuck at bootloader
liberty stuck on bootloader
thunder bolt stuck at boot screen aftering formatting sd card
