Smartass CPU Governor
This is a discussion on Smartass CPU Governor within the Hacking Help forums, part of the Droid X Development category; I've been using the smartass governor on JRummy's Droid Overclock app and I've noticed that my CPU frequencies will often revert to stock-ish values (300, ...
Thread: Smartass CPU Governor
    Points: 1,052, Level: 17
    Overall activity: 1.6%
    thebrianiac's Avatar
    36991
    11
    I've been using the smartass governor on JRummy's Droid Overclock app and I've noticed that my CPU frequencies will often revert to stock-ish values (300, 800, 1000, 1012) from my overclocked ones (300, 759, 1012, 1265). Does anybody know if this is a bug in the app or a feature of the governor?
    Also, on a side note, do I even need to adjust the CPU frequencies to overclock or does the smartass governor do that for me if I set it to stock values?
    Points: 350, Level: 6
    thejamhole's Avatar
    45043
    Aug 2011
    38
    cm7 droid x running rummy's oc app, it NEVER keeps the boot settings, always reverts back to stock. Is this a cm7 glitch? or in the app itself?
    Points: 50,456, Level: 100
    gbrinn's Avatar
    38696
    Headed to Duke University Hospital
    17,710
    727 times
    Never had that problem and I'm on CM7-GB. What's your boot delay setting? Default for overriding stock frequencies is 80 seconds, I think.
    "Master of Puppets I'm pulling your strings / Twisting your mind, smashing your dreams
    Blinded by me, you can't see a thing / Just call my name, 'cause I'll hear you scream
    Master / Master
    " - Metallica
android cpu governor
best android cpu governor
best cpu governor android
cpu governor smartass
smartass cpu
smartass cpu governor
smartass governor
smartass governor android
smartass scheduler
