Bootanimation HELP
Im currently running rooted GB and Im in the process of making a bootanimation. I used after effects which ive used before and then exported the video as multiple jpegs. I then renamed them all in numerical order 0001,0002,0003 ect just as ive always done. then I put them into a part0 folder and a part1 folder and used the orignal desc.text file. i then put all three files on my desktop and right clicked and add files to archieve and saved as bootanimation.zip (store as compression method). when i put it on my phone it worked fine other than i had the FPS up to fast so i changed the desc.text and redid the following steps and now all i get is a black screen for my animation and i cant figure it out for the life of me. ive tried data/local and system/media neither do a thing. I even tried using the stock animation that orignally came with the gb which is techiqually the stock droid x bootanimation anyways but its a black screen too. If anyone has any advice i would greatly appreciate it. Thanks Jake
03-31-2011 12:54 AM
