Overclocking stock Droid X Kernel
This is a discussion on Overclocking stock Droid X Kernel within the Hacking Help forums, part of the Droid X Development category; Hey whats going on guys? I'm new to the forums. I plan on being a regular member and contributing as much information as possible. I ...
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 40
Thread: Overclocking stock Droid X Kernel
    ChadDX's Avatar
    31149
    El Paso, TX
    168
    I just recently traded my Fascinate for a HTC Incredible, then traded to a Droid X.
    So, I'm really digging this DX, seems awesome so far. (Way better than rooted Incredible...)
    My questions is:
    Using the Droid Overclock app from the Market, and going into:
    Set scaling frequencies > Low Voltage > 1.25GHz, 1.0GHz, 800GHz, 400GHz
    Safe overclock? Is this really overclocking the stock kernel?
    Also is this going to cause any problems, or help performance?
    Noticeable gains in speed!, also Quadrant scores went through the roof from what they were completly stock.
    Should I go with Low Voltage, or Medium Voltage? I have read that every phone reacts different, and you need to experiment. I'm just merely asking for your professional, and personal opinions based off your experiances.
    Thank you
    -ChadDX
    Points: 25,696, Level: 96
    Level completed: 35%, Points required for next Level: 654
    Abe21599's Avatar
    Ohio
    4,864
    458 times
    its just about experimenting, just dont set at boot until you ARE SURE its a good setting. a reboot will go back to stock speeds since ur running a script to OC.
    ChadDX's Avatar
    31149
    El Paso, TX
    168
    Okay thanks! So your saying once I reboot (Or turn off my phone) The overclock will return to stock speed? 1.0GHz?
    Abe21599's Avatar
    Ohio
    4,864
    458 times
    yup. so play around with the settings til u find a good speed for ur processor. also, i suggest quickclock advanced. itll help u find appropriate speeds, voltages. and the dev is an active member on here.
    i use QC and Jrummys OC app together for my phone.
    ChadDX's Avatar
    31149
    El Paso, TX
    168
    Quote Originally Posted by Abe21599 View Post
    Thanks. I appreciate it. So don't set boot until I back up and feel comfortable.
    ChadDX's Avatar
    31149
    El Paso, TX
    168
    What voltage do you run?
    Abe21599's Avatar
    Ohio
    4,864
    458 times
    its not a predefined one but its probably close to 70% of the stock ones. but every processor is different.
    ChadDX's Avatar
    31149
    El Paso, TX
    168
    Oh okay. So I should stick to medium voltage just to be safe until I find a good speed and set boot?
    Abe21599's Avatar
    Ohio
    4,864
    458 times
    well if you plan on sticking to med voltage, yes. but changing the voltage will also affect the stability so you gotta play with them both at the same time.
    ChadDX's Avatar
    31149
    El Paso, TX
    168
    I guess in the end for right now im asking what is generally a safe overclock for most devices?
  1. I need baseband and kernel versions for stock 2.3.15
    Last Post: 04-15-2011, 02:11 PM
  2. Flash kernel on Droid X
    By Leffy in forum Droid X Hacks
    Last Post: 01-05-2011, 04:57 PM
  3. Droid X 2.2 Overclock (Kernel Module w/Instructions)
    By FreeWELL in forum Droid X Hacks
    Last Post: 12-20-2010, 05:09 AM
  4. Overclocking the Droid X
    By GrinReaper in forum Droid X Hacks
    Last Post: 11-28-2010, 09:59 PM
  5. Droid X Froyo a problem of a buggy Linux Kernel?
    By gman in forum Droid X General Discussion
    Last Post: 09-30-2010, 01:34 PM
droid x 2.3 overclock kernel
droid x 2.3.3 overclock kernel
droid x kernel
droid x kernels
droid x low voltage kernel
droid x overclock kernel
droid x overclock kernel 2.3
kernel for droid x
overclock stock kernel
overclocking stock droid x
