Modifying framework-res.apk using ADB pull/push commands
This is a discussion on Modifying framework-res.apk using ADB pull/push commands within the Hacking Help forums, part of the Droid X Development category; Hey guys, Can someone point me in the right direction... The guide that I used to follow is somehow no longer on the web, and ...
Results 1 to 7 of 7
Thread: Modifying framework-res.apk using ADB pull/push commands
    Points: 6,788, Level: 54
    Overall activity: 0.6%
    Created Album pictures31 days registered100 Experience Points7 days registeredTagger Second Class
    greevedogg's Avatar
    16608
    CFL
    477
    33 times
    Hey guys,
    The guide that I used to follow is somehow no longer on the web, and I don't remember off-hand what the exact commands were/are...
    But I'd like to change a few icons from the drawable-hdpi folder...
    Can someone lay out the ADB commands, or point me to a thread
    Thanks!
    Points: 18,520, Level: 86
    Level completed: 34%, Points required for next Level: 330
    Overall activity: 4.0%
    31 days registered250 Experience Points7 days registered100 Experience PointsTagger Second Class
    maderschramm's Avatar
    19945
    Madison, WI
    125
    177 times
    the only way I know how to do this is with ninjamorph...
    but the adb commands to do it would probably be:
    cd [the directory you want to pull the files to]
    adb pull /system/framework/framework-res.apk
    decompile, mess with the files
    recompile
    adb push framework-res.apk /system/framework/framework-res.apk
    I'd just use ninjamorph
    greevedogg's Avatar
    16608
    CFL
    477
    33 times
    yeah, i might just have to NM it...but the ADB pull/push would be way faster as I'm changing out 20+ icons....
    i mean, i've done it before, i just can't find the guide that i used before...
    but i think you got it about right, but i think you need to first type 'su' to get superuser, then cd [directory], then pull
    i know you don't need to decompile and recompile the .apk.....just change the .pngs using 7zip to browse the files....
    19945
    Madison, WI
    125
    177 times
    in that case I was right - you're thinking of using adb shell - adb pull is an adb command ran from a terminal or command prompt - thus, you don't need to type SU because you're phone's already rooted and the shell loads it automatically
    so you'd open a terminal
    cd [directory where you want the -res.apk to go] - changes your dir to the one you want
    adb pull /system/framework/framework-res.apk - pulls the framework from your phone onto your computer
    edit files
    open terminal
    cd [directory where changed framework-res.apk is] - goes back to the proper dir
    adb push framework-res.apk /system/framework/framework-res.apk - pushes .apk back into proper position, overwritting old one
    adb pull is an adb command ran outside of the adb shell, so no su required
    Points: 9,994, Level: 66
    Overall activity: 1.2%
    TideFan22's Avatar
    23940
    Florence,Alabama
    3,097
    64 times
    Listen to mad he knows his stuff.
    Sent from the state with 13 National Championships and the winningest bowl team
    Points: 51,541, Level: 100
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    I've updated my ninjamorph guide to include changing out multiple pngs at once using the PC. Its in post #3.
    Points: 9,805, Level: 66
    Level completed: 39%, Points required for next Level: 245
    Tagger Second Class31 days registered250 Experience Points7 days registered100 Experience Points
    trenton's Avatar
    20215
    1,114
    71 times
    Quote Originally Posted by Droid-Xer View Post
    Muahahah...........muuuaahahahahah
  1. Need a little help with framework
    By pablo1010 in forum Droid X Themes
    Last Post: 01-17-2011, 11:00 PM
  2. Framework.res.apk
    By shelooga in forum Droid X Help
    Last Post: 01-13-2011, 04:56 PM
  3. modifying stock lockscreen?
    By Phildo in forum Droid X Hacks
    Last Post: 12-08-2010, 12:21 AM
  4. Modifying Widgets?
    By shazbork in forum Droid X Themes
    Last Post: 11-01-2010, 12:10 PM
  5. Replies: 8
    Last Post: 10-28-2010, 06:38 PM
adb framework-res.apk
adb pull framework-res.apk
framework-res.apk
how to pull framework-res.apk
how to push framework-res.apk
pull framework res apk
push framework-res.apk adb
