Complete WiFi / 3G Switch?
This is a discussion on Complete WiFi / 3G Switch? within the Hacking Help forums, part of the Droid X Development category; Hey there folks. Trying to get the most battery/speed out of my Droid X, and obviously one of the big ones is switching to WiFi ...
Results 1 to 8 of 8
Thread: Complete WiFi / 3G Switch?
    iNinja's Avatar
    26979
    9
    Hey there folks. Trying to get the most battery/speed out of my Droid X, and obviously one of the big ones is switching to WiFi when possible. I've noticed that just enabling WiFi doesn't completely shut off 3G though as in ROMs I was used to on my OG Droid; for example, when sending/receiving an MMS it will throw 3G back on, or even worse if it can't get the right data via WiFi (as sometimes the cookie expires on my network and I have to re-enter log in info) it will switch on 3G and WiFi at the same time, causing a HUGE battery drain and working against what I want.
    So is there some quick way of completely disabling the data connection and enabling WiFi, preferably through a widget? That isn't ugly? Neither my Beautiful Widgets toggle or Widgetsoid seem to do it.
    Thanks guys!
    Points: 10,712, Level: 68
    Level completed: 66%, Points required for next Level: 138
    Dustin0308's Avatar
    24203
    1,490
    37 times
    Airplane mode cuts data connection and allows you to connect via wifi I believe..and I'm not sure about widgets...
    Quote Originally Posted by iNinja View Post
    Thanks guys!
    LiBeRaTeD onePOINTfive
    Points: 1,876, Level: 25
    Level completed: 76%, Points required for next Level: 24
    Created Album pictures500 Experience Points250 Experience Points7 days registered100 Experience Points
    beachy's Avatar
    23929
    Indianapolis Indiana
    285
    Quote Originally Posted by Dustin0308 View Post
    that does work for internet but you can not send texts or make calls.... just internet data... i just tried. but the browser does work with plane mode and wifi turned on... but thats unfortunately not going to help with other phone uses.
    Dustin0308's Avatar
    24203
    1,490
    37 times
    He was talking about completely disabling the data connection and using just wifi to my understanding because of getting interrupted by texts and calls and being able to switch quickly back to where he has data connection..all thru widgets..with airplane mode..you can connect wifi but wont get interrupted by people contacting you..and to the OP...try extended controls in the market..it is like $.99 but gives you many options including airplane mode as a widget..and 3g as widget so you can easily switch between the two..i don't have it but it may be something that may interest you..
    Quote Originally Posted by beachy View Post
    Points: 1,329, Level: 20
    Level completed: 29%, Points required for next Level: 71
    TonyOKC's Avatar
    27044
    Oklahoma City, OK
    33
    Try the SwitchPro Widget, allows you to pick widget size, and what options, I have mine 8 across, with just the options I care about
    Points: 51,541, Level: 100
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Yes switchpro widget isn't free but it allows 2g/3g toggling and is pretty customizable.
    Points: 9,494, Level: 65
    Level completed: 48%, Points required for next Level: 156
    skennelly's Avatar
    17443
    Illinois
    1,319
    44 times
    Both Dazzle and Widgetsoid2.x have that option & are free. Widgetsoid also has the option to place the switches in the notifcation bar.
    Sent from my DROID X in Western Illinois
  1. Complete ROM
    By taylorf16 in forum Droid X Hacks
    Last Post: 12-21-2010, 03:21 PM
  2. Complete Droid X .sbf Flashing Guide
    By maderschramm in forum Hacking Help
    Last Post: 12-08-2010, 12:06 AM
  3. Anyone have the Complete Anroid Guide ebook?
    By Swish in forum Droid X General Discussion
    Last Post: 11-30-2010, 02:52 PM
  4. Replies: 4
    Last Post: 08-12-2010, 02:10 PM
  5. Complete Enjoyment - No problems... Anyone else?
    By X Angel in forum Droid X General Discussion
    Last Post: 07-17-2010, 06:50 PM
3g wifi switch
android wifi 3g switch
beautiful widgets plane toggle doesn't work
droid x switch to wifi
how to get droid to switch between wifi and 3g
how to switch droid from wifi to 3g
how to switch from wifi to 3g on droid
how to switch to wifi on thunderbolt
switch between wifi and 3g on android
wifi 3g switch
