I tried restoring a backup and now I can't get it to turn on at all. How do I get it to turn on?
This is a discussion on Help!!!!! within the Hacking Help forums, part of the Droid X Development category; I tried restoring a backup and now I can't get it to turn on at all. How do I get it to turn on?...
what did it say after restoring the backup ?
It said the usual then I pressed reboot and it went off. When it is plugged in the green indicator light is on also.
Im not sure of the exact wording but it looked like it usually does when I have restored backups before.
Is there a button combo I can push to get to clockwork?
what was your battery at when you were restoring
Low. Around 20 percent.
The indicator light did flash red just before it went off.
Screen just came back on. I think it is working now.
dead battery. plug it into the wall and give it about 30 mins before trying to power on
