i installed the new update from team blackhat 2.3.1 and my phone keeps on rebooting and i have no way to get into clockwork recovery. can anyone help me out with this or is their nothing that i can do.
This is a discussion on my droid keeps gettin stuck on boot logo and restarting!?!? can someone help? within the Hacking Help forums, part of the Droid X Development category; i installed the new update from team blackhat 2.3.1 and my phone keeps on rebooting and i have no way to get into clockwork recovery. ...
i realized what i did wrong i did not wipe data and cache..now i need to find a fix
Boot into stock recovery(home button + power until droid w/exlamation point appears) then hit search key. From there you can wipe data & cache. I believe that will fix you, but i'd wait for a second opinion.
Sent from my DROIDX
Ya try stock recovery like skennelly said. But I think you'll have to SBF as there is no 2.3.1 for the X. Did the install specifically state it can work on the X?
I did exactly that and it worked, now I am running Runic with then 2.3.1 update thanks a lot!
