Return to stock
This is a discussion on Return to stock within the Hacking Help forums, part of the Droid X Development category; I have a droid x running 2.2.1. I just recently decided to root my phone. I then started to do research about roms, so i ...
Results 1 to 10 of 15
Thread: Return to stock
    HeartAttackJeffrey's Avatar
    24269
    Johnstown, Ohio
    6
    Return to stock
    I have a droid x running 2.2.1. I just recently decided to root my phone. I then started to do research about roms, so i then got rom manager and flashed a rom. I did the backup and all that. My friend also has a rooted droid (his is a 2). He said that i had too many usless files on my sd card and deleted folders. One had my backup in it. I am very mad at him because im having issues with my phone, but with it rooted and a rom i cant take it back to verizon. So i was wondering if anyone has a solution for me. I have done a lot of research about ways to do it, which none have helped.
    Points: 51,541, Level: 100
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    If you have no stock backup, you will have to SBF back to stock. What is your system version? 2.3.15 or 2.3.340
    24269
    Johnstown, Ohio
    6
    2.3.340
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    Then you need the SBF for 2.3.320 and the updater for 2.3.340. The links are in my signature. Follow them. Then follow the directions to SBF here http://www.droidxforums.com/forum/dr...ing-guide.html
    24269
    Johnstown, Ohio
    6
    So if i do this then unroot i can take it back to verizon?
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    SBF will clear your phone of everything. It will be back to stock
    24269
    Johnstown, Ohio
    6
    Thanks man!
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    sure no problem
    Points: 38,766, Level: 100
    Overall activity: 64.5%
    1KDS's Avatar
    3981
    6,904
    573 times
    You will have to be rooted to install the TBH patches, so you will have to delete the bootstrap files, delete su, unroot, factory reset and return. You can try the 2.3.340 system only sbf, it might be better for your situation.
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,334
    786 times
    The patches are update.zips that can be installed via stock recovery though...right 1kds? Or no?
  1. Return Key
    By Bert in forum Droid X Help
    Last Post: 12-18-2010, 01:57 AM
  2. Having to return my X for another one???
    By dnelms in forum Droid X Help
    Last Post: 11-24-2010, 06:25 PM
  3. Return to stock?
    By Hoax55 in forum Droid X Themes
    Last Post: 09-28-2010, 09:52 PM
  4. Return X for Incredible
    By Dilly4693 in forum Droid X General Discussion
    Last Post: 08-03-2010, 09:47 PM
droid x 2.2.1 stock backup
droid x return to stock
droidx return to stock
how return my droid x to stock
return droid 2 to stock
return droid ii to stock
return droid x to stock 2.2.1
return droidx back to stock
return stock droid x 2.21
return to stock 2.2.1 droid x
