Malfunctioning app trouble shooting:
-first check all the setting options in the app.
-if its an internet app, toggle airplane plane mode, autosync.. . ect.
-use cache cleaner to clean phones cache
-still not working.. clear app data
If that doesn't work....
-unistall app
-redownload and install app
Something like that..
{{ WugFresh }}
01-05-2011 03:01 AM
Originally Posted by
eric eakin
...and can you add how to rename, move and if it is necessary to keep them on your phone?
Thays in my "How To use Droid X Bootstrap" in hacking guides subforum.
eric eakin
I was reading through that the other day... I must have missed it. I'll look again then
Actually, its not very clear in there. I haven't updated that in a while. I'll get to it tonight then and add that in there.
How to solve any technical problem:
1. Hit the button with the little magnifying glass on it.
2. Type your question into the search field, and initate search.
3. Read the relevant resources Google suggests.
4. Discover the answer to your problem.
5. Apply that knoledge.
LOL! It needs to be said. Or simply,
Step 1: Google it!!!
Step 2: Google it!!!
Step 3: Did you try using Google?
{{ WugFresh }}
Droid-Xer
it was clear enough... i just missed it, oops. must have been side tracked!
*wait, i think i re-read it after you updated!
Addicted to technology but don't always get it!
X 2
eric eakin
Lol, ya just updated the thread.
@Wug...true it needs to be said but if people don't read my guides/ask for help then what would I do with my free time!?
Google will bring them to your guides. : )
{{ WugFresh }}
Droid-Xer
How to prepare for an OTA update...
4. If you ever themed, ROMmed, or manually deodexed, then install this zip file via Clockwork Recovery to odex your phone
928DROID_Back_to_stock_ODEX
Also applies if you have ever overclocked or made any edits to your build.prop file.
{{ WugFresh }}
