Ok well I unrooted but the update still wouldn't take. Im thinking I should do a wipe but im concerned about what will happen when I restore my backup with the new OS. Any opinions would be appreciated.
This is a discussion on [How To] Be Ready For Anything within the Hacking Help forums, part of the Droid X Development category; Ok well I unrooted but the update still wouldn't take. Im thinking I should do a wipe but im concerned about what will happen when ...
What update are you referring to?
So if im on rooted GB I just use root explorer and find updater.apk and rename it to update.bak? And I should never have to worry about losing root right
Sent from my ROOTED OC'D GINGERBREAD X
The update to 2.3.340.
you likely have some bloatware missing, you can hit the search key as soon as it starts to install to see where the ota fails, you should restore a stock backup or reinstall any bloat you may have deleted/renamed/frozen. Alternatively, you can flash maderstcok or the TBH 340 sbf update.zip to get to 2.3.340. You can't restore a backup on a new system version, do not restore a 2.3.15 backup when you are on 2.3.340.
Great post!!!
Westy
CM4DX - 7.1
Android Version 2.3.7
Thanks
