[GUIDE] Modifications: Risk vs. Reward
This is a discussion on [GUIDE] Modifications: Risk vs. Reward within the Hacking Help forums, part of the Droid X Development category; I'm putting this guide together to help new users decide if certain modifications are for them or not. There are many mods being thrown on ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Like Tree21Likes
Thread: [GUIDE] Modifications: Risk vs. Reward
    Points: 40,759, Level: 100
    Overall activity: 13.1%
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,330
    786 times
    I'm putting this guide together to help new users decide if certain modifications are for them or not. There are many mods being thrown on phones that most users don't even know what they do. Research is the best resource. Don't do something to your phone without knowing what it does and how to uninstall it.
    ROOT
    Root is having administrative access to your phone. This allows you full control over all aspects of your phone to include system files.
    Benefits
    1. You can remove unwanted system apps (bloatware) on your phone.
    2. You can improve speed by overclocking the CPU
    3. You can create a wireless hotspot
    4. You can install custom themes for
    5. You can install custom ROMs
    Risks
    1. You will void your one year replacement warranty if VZW finds out you're rooted
    2. You open your phone up to powerful apps/modifications that can cause serious damage if you're not careful with them.
    Removing Bloatware
    This involves either deleting, renaming, or freezing unwanted system apps.
    Benefits
    1. Improved battery savings by removing constantly running system apps.
    2. Cleaner looking app drawer
    Risks
    1. Removing a vital system app can cause serious issues with your user interface.
    2. Deleting, renaming, or freezing system apps may cause issues with receiving OTA updates from VZW.
    3. Some system apps may not work if a complimentary app is removed.
    Overclocking
    This involves using a third party app to increase the clock speed over the stock 1.0ghz processor.
    Benefits
    1. Improved performance.
    2. Faster transitions.
    Risks
    1. Shortened processor life.
    2. Overheating which also can lead to a lower life span for the processor.
    3. When "Set at boot" option is selected, bootloops can occur if overclock speed is not set at a stable speed.
    Tethering
    This involves downloading a tethering app that will turn your phone into a ad hoc wireless hotspot.
    Benefits
    1. Ability to connect other wireless devices to the internet via the phones 3G signal.
    2. No need for an additional internet provider.
    Risks
    1. Heavy battery drain, which can lower the life span of the battery.
    2. Tethering large amounts of data will catch the eye of VZW.
    TBH 3G Hotspot Patch
    This is the official VZW hotspot being hacked into to provide 3G hotspot benefits without being charged for its use.
    Benefits
    1. Better/truer connection than ad hoc tethering.
    2. No need to pay $20 for use of the official VZW service.
    Risks
    1. This is a direct violation of your terms of service with VZW.
    2. VZW will terminate your contract if this is found.
    3. Using large amounts of data will also put you on VZWs radar.
    Removing the data governer/throttling
    VZW lowers data speeds to users who use more than 5gb and during peak bandwidth usage times and this hack removes that data limit. This does not necessarily increase speeds for average users.
    Benefits
    1. More constant data speeds for heavy users.
    2. No drop in down/upload speeds.
    Risks
    1. You are modifying the services.jar, if you don't know what this is, perhaps you shouldn't be modifying it.
    2. Can no longer turn off 3G in settings.
    Themes
    Themes modify the framework of your phone.
    Benefits
    1. The ability to customize your phone.
    Risks
    1. Bootlooping if not installed correctly.
    ROMs
    ROMs change the entire system of the phone.
    Benefits
    1. Increased performance.
    2. Easier to use interface.
    3. Ability to customize the system.
    Risks
    2. Bricking your phone and needing to SBF.
    3. Permanent brick.
    These are a few of the more common modifications taken on by many users. If I left something out or if you would like something described more in detail, let me know. This is more of a guide for new users rather than more experienced users. So help if you can and keep unproductive comments to yourslef. Thanks, Rob
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,330
    786 times
    Reserved for more rambling
    Hackja4fun likes this.
    Rescue Squad
    Points: 30,899, Level: 100
    DebianDog's Avatar
    6359
    "The Sticks", Virginia
    4,379
    331 times
    How can overclocking your CPU result in faster download speeds? It can't
    Otherwise very nice.
    Beamed from my DroidX
    Backnblack's Avatar
    26
    2,818
    136 times
    Quote Originally Posted by DebianDog View Post
    Damn, Beat me to it...
    Nice write up tho...
    Droid-Xer likes this.
    Only the Skilled Survive
    1. Never be unarmed.
    2. See Rule #1
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,330
    786 times
    Will edit. Pardon my lack of common sense
    Points: 1,340, Level: 20
    Level completed: 40%, Points required for next Level: 60
    bratliff's Avatar
    22602
    Ky
    142
    You know if I had read this before I probably would not have rommed..lol..this is a bit more serious than the og droid..
    Points: 29,830, Level: 99
    Level completed: 90%, Points required for next Level: 170
    Overall activity: 62.8%
    1KDS's Avatar
    3981
    6,817
    558 times
    Nice write up man, good idea!
    Discussion Ender
    Droid-Xer's Avatar
    5096
    El Paso, TX
    10,330
    786 times
    Quote Originally Posted by 1KDS View Post
    Hopefully it'll answer a few questions before they're asked.
    1KDS's Avatar
    3981
    6,817
    558 times
    or at least an easy link to post when they do get asked
    Points: 23,529, Level: 94
    Level completed: 18%, Points required for next Level: 821
    Overall activity: 1.2%
    Abe21599's Avatar
    Ohio
    4,864
    456 times
    you sir get one more sticky
  1. Undervolting Guide
    By xrazedx in forum Droid X Hacking Guides
    Last Post: 06-16-2011, 11:48 PM
  2. Best Shopping/Reward app...ShopKick!?
    By Hostility6 in forum Droid X Apps
    Last Post: 12-29-2010, 10:40 PM
  3. Guide to install 2.2 sbf?
    By Charlie97L in forum Droid X Hacks
    Last Post: 11-06-2010, 01:35 PM
  4. ROM terminology guide??
    By bobthebob in forum Droid X ROMs
    Last Post: 10-28-2010, 10:10 AM
  5. Mac Rooting Guide
    By Carolinapimp in forum Droid X Hacks
    Last Post: 07-22-2010, 05:09 PM
droid x root risk
hacking shopkick
highest level in shopkick
highest level on shopkick
highest shopkick level
how many levels are in shopkick
how many levels are there in shopkick
how many levels in shopkick
how many shopkick levels
how many shopkick levels are there
shopkick hack
shopkick hacks
shopkick levels
what do levels do in shopkick
what do shopkick levels do
