The ultimate wrong doings of...
This is a discussion on The ultimate wrong doings of... within the Hacking Help forums, part of the Droid X Development category; The users. First off I want to make this very clear, I am not responsible for anything nor is droidxforums for any damages done to ...
Closed Thread
Page 1 of 5 1 2 3 ... LastLast
Results 1 to 10 of 48
Like Tree13Likes
Thread: The ultimate wrong doings of...
    Your first GroupThree Friends250 Experience PointsTagger Second Class100 Experience Points
    B16's Avatar
    12
    Somewhere, SC
    446
    93 times
    Exclamation The ultimate wrong doings of...
    The users. First off I want to make this very clear, I am not responsible for anything nor is droidxforums for any damages done to devices due to root, since it was up to the user to make the decisions they make. Thank you, please continue to read.
    1. First off I am posting this for reasons that were obvioulsy not too obvious.
    2. If you chose to delete anything other than something that can be downloaded from the market, YOU took that risk. You have potentially just bricked your device.
    3. DO NOT DELETE ANYTHING THAT HAS "BLUR" IN ITS FILE NAME.
    4. DO NOT try to flash a custom recovery via Rom Manager then wonder why your phone is stuck with a cool new Motorola logo.
    5. This thread will be updated very frequently, before posting questions and what not, just post your problem, no questions please, I will be using this to help as many of you as possible.
    6. Most importantly do not mess with the framework right now, there is many $600 papers weights laying around now.
    7. DO NOT TOUCH BACK UP ASSISTANCE UNLESS ITS WINDY IN YOUR HOUSE OR OFFICE AND YOU NEED A PAPER WEIGHT.
    Thank you.
    B16
    My Faqs:
    wicked_beav
    @b16a2smith What are the current thoughts on metamorph & ninjamorph? Should we avoid? Can we just wipe to stock in recovery if issues occur?
    ANSWER: Metamorph will surely become available as Stericson finds out if he can mess with it along with any other themer. So, YES, please do avoid messing with Blur-res.apk
    wicked_beav
    I see you had mentioned the framework. That being said we should not be able to use Metamorph or Ninjamorph? If we did, is there an option to boot to recovery and wipe to restore to stock.
    ANSWER: Understand we were NOT meant to have root, so when you wipe and try to restore the phone back to normal the phone is assuming you have not touched any proprietary files, hence it will leave things as is and you will either have to just resign back in to google and/or you will have a pretty brick.
    Webs3r
    @b16 I guess, I shouldn't have done this this early. But I thought I might be able to help. Anyways,
    I tried making a theme for my Droid X. I fixed up the framework-res.apk (which is blur-res.apk [b16]), and pushed it to my phone. It's resarted, and went into a constant loop of the bootanimation. Is there an .sbf available for the Droid X? I've used every option in the recovery menu, and no luck.
    ANSWER: This is unfortunately a good example of what happens when you mess with the files Moto has seemingly locked down tight. In other words ladies and gents, REFER to bullets numbered 1-7.
    jeffjano
    @b16a2smith so if you really didnt "delete" anything and just rooted and renamed. will a factory reset unroot?
    ANSWER: No it will not unroot. Even if you rename those files you will still possibly get these:
    MORE TO COME
    Follow me on TWITTER!
    Please read this before you root your X!
    Feel free to thank me if you think I helped. (<<<The button is on this left)
    Check out my new BLOG!
    X Pursuant Achievements:
    Jaxidian's Avatar
    47
    Indianapolis
    694
    48 times
    Again, my suggestion is to say out loud, "I am happy if I do this and have to go back to Verizon and pay $600 for a brand new Droid X after I break it." If you cannot do that and be happy with it, then do not experiment with your phone yet. This is too rough of a process at this point. At some point in the future, it will be better understood and safer but you should still say that and know it's a possibility.
    HalfFrozen's Avatar
    374
    AZ
    23
    I am HalfFrozen, and I support this message.
    [In your phone, encrypting yoar hardwarez]-----
    wicked_beav's Avatar
    408
    Detroit, Michigan
    8
    Mike919's Avatar
    1353
    Erie, PA
    86
    As B16 suggested. Do NOT mess with frameowork-res yet. (remember we're only a day into root) That obviously would include any morphing. If you want to try this, you do so at your own accord knowing you will probably end up with a device that won't boot. There are warnings everywhere about this. Patience!
    Good call on NOT flashing a recovery! I knew that would be a good point to make known! (not that you didn't either!)
    follow me, or feel free to ask me questions on twitter @Mike91908
    Droid X
    Points: 1,712, Level: 24
    jhankg's Avatar
    17
    Summerfield, NC
    196
    10 times
    Just don't do anything stupid until (or if I guess) the full sbf pops up.
    Mike919's Avatar
    1353
    Erie, PA
    86
    Quote Originally Posted by jhankg View Post
    +1.... exactly... and tested for that matter... still not even sure what version of RSD is being used... (unless i fell out of the loop)
    Droid X
    Tagger Second Class31 days registered250 Experience Points7 days registered100 Experience Points
    Ack's Avatar
    Droid Network News Team
    188
    87
    8 times
    Just a quick note for people:
    You can install BusyBox (following my guide or the install process by Birdman) and Wifi Tether and Titanium Backup all work with root access. It's the other stuff that B16 said that you shouldn't do just yet.
    Just trying to make it clear what is working right now.
    I'm Ack, a college student who runs two tech companies, works at a major consulting firm, and does personal consulting as well; oh and I play soccer and volleyball on the side . Follow me: here
    B16's Avatar
    12
    Somewhere, SC
    446
    93 times
    Please push this in twitter and any other social media network please, this needs to be known.
    B16's Avatar
    12
    Somewhere, SC
    446
    93 times
    OP updated.
    smiley68 likes this.
Closed Thread
  1. Ultimate Live Wallpaper (Mario!)
    By Rhith in forum Droid X Wallpapers
    Last Post: 08-01-2010, 12:18 PM
  2. Am I wrong?
    By supahrob in forum Droid X General Discussion
    Last Post: 07-14-2010, 01:32 AM
  3. May the force...shoot wrong line..
    By Dark_Jedi in forum New Member Introductions & Site Assistance
    Last Post: 07-08-2010, 08:11 PM
What happens if I root my droid x
boot loops
bootloops
droidxforum.net
list of wrong doings
list of wrong doings in human society
list of wrongdoings
ultimate droid for droid x
what happens if you root your droid x
what happens when i root my droid x
what happens when you root a droid
what happens when you root a droid x
what happens when you root a droid?
what happens when you root your android
what happens when you root your droid x
