Need help with Switching ROMs (ROM Manager/Clockworkmod Recovery)
This is a discussion on Need help with Switching ROMs (ROM Manager/Clockworkmod Recovery) within the Hacking Help forums, part of the Droid X Development category; I'm a little unclear on how ROM Manager and Clockworkmod Recovery work together. I have been using ROM Manger to make backups and restore my ...
Results 1 to 10 of 11
Thread: Need help with Switching ROMs (ROM Manager/Clockworkmod Recovery)
    Points: 10,159, Level: 67
    Level completed: 28%, Points required for next Level: 291
    Overall activity: 1.0%
    1000 Experience Points500 Experience Points250 Experience Points100 Experience Points7 days registered
    Growler48's Avatar
    230
    Maryland
    182
    I'm a little unclear on how ROM Manager and Clockworkmod Recovery work together. I have been using ROM Manger to make backups and restore my backups from a fully booted system. Now, I want to install a few ROMs and switch back and forth between them to experiment. When I do so, I will need to be in Clockworkmod recovery so I can wipe the cache/data/factory reset. Once I do so, can I restore a ROM backup I made in ROM Manager? Or do I need to make a specific backup in Clockworkmod recovery to use while in Clockworkmod recovery? It's not clear to me whether or not I have to use one program as a stand alone or if the two are compatible with each other. Thanks for any help.
    Rescue Squad
    Points: 42,712, Level: 100
    DebianDog's Avatar
    6359
    "The Sticks", Virginia
    4,384
    332 times
    Clockwork recovery is built in. Think of it as the green boot menu. The rom manager as the droid front end
    Beamed from my DroidX
    Points: 146,349, Level: 100
    Overall activity: 71.4%
    Garemlin's Avatar
    15
    Delaware
    3,846
    358 times
    Points: 2,665, Level: 31
    Level completed: 44%, Points required for next Level: 85
    lifebeginsfriday's Avatar
    4332
    Virginia
    155
    I actually run into issues trying to do everything from rom manager- other then downloading... imo its easier to do install/swaps/backups from bootstrap.
    DX - Apex 1.3 - OTA 2.2.1 - And loving it!. I-What!!!
    Points: 46,436, Level: 100
    psychotic_penguin's Avatar
    5117
    Rapid City, SD
    5,088
    243 times
    Since the X has a locked bootloader you need Droid X Bootstrapper to properly install ROMs, themes ect. You can still download through ROM Manager, but go to the clockworkmod/download folder on your SD card and move the file you downloaded to the root of your card and then install it via Bootstrapper.
    Growler48's Avatar
    230
    Maryland
    182
    I actually didn't realize that Droid X Bootstrapper (what I use to enter Clockworkmod Recovery) and ROM Manager (what I use for backing up/restoring only) are from the same developer and that they are in fact interchangeable. I was using them for completely separate functions. I went into Clockworkmod Recovery and it automatically found my backups made w/ROM Manager w/o putting them on the SD card root directory. Great stuff. Thanks to everyone for the help!
    Rescue Squad
    DebianDog's Avatar
    6359
    4,384
    332 times
    Quote Originally Posted by psychotic_penguin View Post
    I don't have to move things around I just navigate through the menu to the file
    Points: 2,975, Level: 33
    Level completed: 50%, Points required for next Level: 75
    Overall activity: 0.6%
    drjimbeam's Avatar
    18382
    Lacey WA
    429
    30 times
    I still dont get it.. In not one of the tuturials (I think 5 on this site) about bootstrap does it ever say anything about switching between roms. I see alot about back up and restore.. but nothing about switching between two installed roms.
    I have a computer with windows xp, windows 7 64, windows 7 32 and ubunto. I can boot up and select which OS I go into. I see no mention anywhere about something like this with bootstrap. unless I am wrong it is either installed or its not with bootstrap. You have to back up and restore everytime you want to "switch" (more like reinstall if this is the case)?
    Am I missing something or can switching not actually be done?
    Points: 27,939, Level: 98
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    Quote Originally Posted by drjimbeam View Post
    cant be done. dont think theres a way possible to partition the internal memory to be able to 'dual boot' on the phone with the locked bootloader.
    drjimbeam's Avatar
    18382
    Lacey WA
    429
    30 times
    Thanks.. So many posts like this one that are confusing.. Not switching between roms, really uninstalling and reinstalling them. I Have only tried Gummyjar 2.1 and 2.5 no others. To damn lazy to keep uninstalling and reinstalling.
  1. Help with Clockworkmod recovery
    By maxxram in forum Droid X Hacks
    Last Post: 02-03-2011, 10:51 PM
  2. clockworkmod recovery question
    By nater in forum Droid X FAQs
    Last Post: 10-19-2010, 09:13 PM
  3. Replies: 1
    Last Post: 10-06-2010, 01:23 PM
  4. clockworkmod recovery errors?
    By mps623 in forum Droid X Hacks
    Last Post: 08-22-2010, 11:06 PM
  5. ClockworkMod Recovery on X
    By TheBeavertownKid in forum Droid X Hacks
    Last Post: 08-18-2010, 01:54 PM
changing roms on droid x
changing roms with rom manager
clockworkmod droid 2
droid x switching roms
how to switch roms with rom manager
rom manager download location
rom manager help
switching roms droid x
switching roms with rom manager
switching roms with rommanager
