Installing Busybox on rooted Droid X
This is a discussion on Installing Busybox on rooted Droid X within the Hacking Help forums, part of the Droid X Development category; BusyBox combines many common Unix utilities into one executable and makes them available for root users. It's very useful for getting into the android file ...
Results 1 to 10 of 10
Like Tree5Likes
  • 4 Post By Ack
  • 1 Post By Ack
Thread: Installing Busybox on rooted Droid X
    Tagger Second Class31 days registered250 Experience Points7 days registered100 Experience Points
    Ack's Avatar
    Droid Network News Team
    188
    87
    8 times
    Post Installing Busybox on rooted Droid X
    BusyBox combines many common Unix utilities into one executable and makes them available for root users. It's very useful for getting into the android file system and checking things out or hacking it more. This is a step by step guide to installing BusyBox on your Droid X.
    First download the BusyBox binary from here. Then attach your phone with a USB cable and mount the sdcard. Copy the BusyBox binary to the root folder of your sdcard. Make sure your X is rooted first then open up ADB and open a shell on your phone.
    Code:
    adb shell
    Next you need to login as root
    Code:
    $ rootshell
    and enter the password.
    Mount the /system folder to write to
    Code:
    # mount -o remount,rw -t yaffs2 /dev/block/mtdblock3 /system
    Check and see if /system/xbin folder exists and if it doesn't create it
    Code:
    # mkdir /system/xbin
    Go to the xbin folder and move the busybox binary from your sdcard to the xbin folder
    Code:
    # cd /system/xbin
    # cat /sdcard/busybox-armv61 > busybox
    Give BusyBox permissions to install
    Code:
    # chmod 755 busybox
    Remount the /system folder as read only
    Code:
    # mount -o ro,remount -t yaffs2 /dev/block/mtdblock3 /system
    You may now run the busybox binary and use the built in programs from anywhere in the shell.
    I'm Ack, a college student who runs two tech companies, works at a major consulting firm, and does personal consulting as well; oh and I play soccer and volleyball on the side . Follow me: here
    X Pursuant Achievements:
    Jaxidian's Avatar
    47
    Indianapolis
    694
    49 times
    Nice, thanks!
    InfamousDX's Avatar
    435
    485
    16 times
    Thanks!
    [Now what do I do with it???]
    Ack's Avatar
    188
    87
    8 times
    Quote Originally Posted by InfamousDX View Post
    Thanks!
    It's basically just some extra programs that come standard in linux distros, commands like echo and cp (and a ton of other basic linux commands) are allowed with busybox. If your not a developer this probably won't matter much to you though.
    Your first Group250 Experience PointsRecommendation Second ClassThree Friends100 Experience Points
    titans's Avatar
    52
    Why do you want to know?
    240
    14 times
    Just thought I'd offer a non adb shell method that works for people with the original Droid, so it shouldn't be a problem with the X. Depending how Android literate you are my directions may be more hard. (Root Explorer needed)
    Download Titanium Backup from the market
    Open it up and let it install Busybox
    Open Root Explorer and search Busybox
    Copy that file that shows up
    Paste file in /system/bin and /system/xbin
    If this doesn't work for you let me know and I'll remove it, this method worked on the Droid.
    Ack's Avatar
    188
    87
    8 times
    That sounds like it should work, not sure if titanium would install it correctly but someone would have to try it to find out.
    Quote Originally Posted by titans View Post
    Well tried this method and when you install Titanium Backup, it will give you an error stating it could not acquire access and to make sure busy box is installed. I have root access on my phone, but noticed that there was an option that will let you update busybox and install it correclty. Once I did that Titanium Backup opened up fine and work. So what I gathered if you install Titanium Back Up let it search for the busy box update and everything will work at least it did for me. Yes you still have to manually copy the files to /system/bin, /system/xbin.
    Ack's Avatar
    188
    87
    8 times
    Quote Originally Posted by drvfasr View Post
    It's good someone tried it then. Since titanium uses BusyBox functions that's why it doesn't really work. Still good information to know.
    Banned GetPhuct's Avatar
    2671
    5
    What is the busybox I installed off the market? Also Titanium backup says I have busy box 1.16.0 installed. I thought we copied busybox files while roooting? I didn't get it via adb. Just trying learn :-) Thanks
    Ack's Avatar
    188
    87
    8 times
    Quote Originally Posted by GetPhuct View Post
    The app on the market can do it for you if don have RW access. This method allows you to do it if you don't have RW access. You do have BusyBox installed if Titanium says that you do. This guide is also for people who did not install BusyBox when they were rooting their phone.
    GetPhuct likes this.
  1. If droid X can not be rooted will you still buy
    By pc747 in forum Droid X ROMs
    Last Post: 09-29-2013, 01:12 AM
  2. Now rooted, what app for WiFi Tether?
    By InfamousDX in forum Droid X Apps
    Last Post: 02-07-2011, 02:15 AM
  3. So now that I'm rooted... whats the situation with OTAs?
    By craig1989 in forum Droid X Hacks
    Last Post: 07-27-2010, 09:40 AM
  4. So now that I'm rooted... whats the situation with OTAs
    By craig1989 in forum Droid X General Discussion
    Last Post: 07-22-2010, 08:20 PM
  5. Installing FroYo on my G1...
    By Jaxidian in forum Off-Topic Discussion
    Last Post: 07-13-2010, 12:34 AM
android busybox download
busybox android download
busybox droid x
busybox for android download
busybox for droid x
busybox on droid x
droid x busybox
droid x busybox install
how to install busybox on droid x
what is busybox android
