Remove deodex from phone?
This is a discussion on Remove deodex from phone? within the Hacking Help forums, part of the Droid X Development category; Other than rooting and deodexing, what all has been done or changed on the phone? (Are you using any launcher, installed any ROMs/themes?)...
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Remove deodex from phone?
    Points: 23,189, Level: 93
    Level completed: 84%, Points required for next Level: 161
    250 Experience PointsCreated Album pictures100 Experience PointsThree FriendsTagger Second Class
    hollywood's Avatar
    2093
    Boise, ID
    1,369
    50 times
    The Droid was BORN great
    "Be not afraid of greatness. Some are born great, some achieve greatness, and some have greatness thrust upon them..." -William Shakespeare
    Points: 2,468, Level: 30
    Level completed: 12%, Points required for next Level: 132
    Mudig's Avatar
    9001
    96
    Nothing else has changed other then installing that wick tether but it worked fine before deodexing.
    hollywood's Avatar
    2093
    Boise, ID
    1,369
    50 times
    Does it do it with all the widgets, or just specific ones? Also, do both the Motorola Widgets and Android Widgets do the same thing?
    Mudig's Avatar
    9001
    96
    It does it with all, including motorola.
    hollywood's Avatar
    2093
    Boise, ID
    1,369
    50 times
    Quote Originally Posted by Mudig View Post
    Hmmm... I'd say do an SBF and download Titanium Backup to save all your apps...
    Mudig's Avatar
    9001
    96
    It's ok I ended up doing a factory reset. All I wanted was to use a theme. I had no idea it would be complicated.
  8. #17
    Points: 27,939, Level: 98
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    did that fix ur issue?
  9. #18
    Mudig's Avatar
    9001
    96
    Yeah that fixed everything.
  1. [HOW-TO] Manually deodex your phone.
    By Webst3r in forum Droid X Themes
    Last Post: 08-17-2012, 07:48 AM
  2. Deodex your DX in 5 minutes
    By joneee in forum Droid X Themes
    Last Post: 03-03-2011, 07:12 PM
  3. 928 deodex then invertnito
    By Cukies in forum Droid X Themes
    Last Post: 10-15-2010, 04:36 PM
  4. Deodex problems/ other
    By jar249 in forum Hacking Help
    Last Post: 10-08-2010, 11:25 PM
  5. Replies: 7
    Last Post: 07-16-2010, 07:55 PM
how to remove deodex
how to uninstall deodex
odex deodex ultimate
remove deodex
un deodex
un deodex atrix
undeodex
undeodex droid 2
undo deodex
uninstall deodex
