Z4 Mod to root work?
This is a discussion on Z4 Mod to root work? within the Hacking Help forums, part of the Droid X Development category; Just saw the Z4 Mod available on Appbrain and there are users stating it works on Droid-X (And even on VZW which I have) but ...
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Like Tree2Likes
Thread: Z4 Mod to root work?
    kevnad1966's Avatar
    17022
    Just saw the Z4 Mod available on Appbrain and there are users stating it works on Droid-X (And even on VZW which I have) but I have not had success, even with powering the Droid-X off and back on before running the Z4 program (1 touch root) but all I get is a spinning progress indication and a message stating it's running an exploit to obtain root priveledges. Anyone have success with this??
    I have tried some other 1 touch root apps listed on this site, and even some not so much 1 touch, but it seems VZW or Motorola has this baby locked down pretty well.............
    Kevin
    Points: 2,456, Level: 30
    Level completed: 4%, Points required for next Level: 144
    57fuelieroadster's Avatar
    181
    Texas
    70
    Kevin....make sure you have USB debugging checked under settings-applications-development-USB debugging. It worked the first time for me. 57fuelieroadster
    killathrilla's Avatar
    10232
    165
    37 times
    How long is it supposed to take to "Run exploit in order to obtain root acess..." been spinning for about 3 minutes now.
    Points: 77,892, Level: 100
    Overall activity: 71.7%
    20,509
    885 times
    It only took about 30 seconds when I used on the Galaxy Tablet....
    Points: 27,939, Level: 98
    Abe21599's Avatar
    Ohio
    4,864
    459 times
    Quote Originally Posted by killathrilla View Post
    try cancelling it and restarting ur phone
    10232
    165
    37 times
    The app definatley worked for my fully updated DX, i recommend rebooting after you download and install z4root, then root your phone.
    MrSpeed3's Avatar
    18614
    137
    It worked for me with out a glitch. Took about 30 seconds for me on my DX. Also recommend this app to a couple of people and they also had the phones rooted in no time. Power down/poet up phone n run app b4 anything else.
    Mazdaspeed3= Boosting all 6 gears
    Droid X= Overclocking 110% of the time.
    Points: 935, Level: 16
    Level completed: 35%, Points required for next Level: 65
    Foxfire's Avatar
    15847
    Cheese Land
    14
    I rooted last night....z4root....no problem loading. Maybe took 1 1/2 to 2 minutes.
    I read where someone wrote that they were "Blot" free after the load, but it seems to me that I can not remove some of the stock apps on my X. Like for example, "Kindle" (Amazon) or Blockbuster. Tried, but can't seem to get rid of them and I don't want them....any suggestions?
    Points: 977, Level: 16
    Level completed: 77%, Points required for next Level: 23
    kb51's Avatar
    6848
    53
    Question
    Quote Originally Posted by Foxfire View Post
    Mine is rooted now what's the big deal
    Points: 2,121, Level: 27
    Level completed: 81%, Points required for next Level: 29
    Ryan M's Avatar
    16301
    Dayton, Ohio
    258
    14 times
    Just d/l root explorer from the market and either delete the .apk's of the apps you dont want (when vzw pushes updates you will need these back) or rename them to .bak then poof they are gone
    good luck
    Droid X
    Rooted
    clock 1 Ghz
    Gingerbread 2.3.3 - Thanks TBH !!
    Blurred and loving it!
  1. Replies: 3
    Last Post: 11-04-2010, 01:18 AM
  2. Mobile root vs. ADB root vs. one touch root?
    By Wicken in forum Droid X Hacks
    Last Post: 10-28-2010, 01:44 AM
  3. I can confirm Droid2 root does work on 2.2 OTA
    By pitchblack86 in forum Droid X General Discussion
    Last Post: 09-22-2010, 09:24 AM
  4. *82 does not work with Parrot CK3100 car kit (and a work-around)
    By AndroidScott in forum Droid X General Discussion
    Last Post: 09-03-2010, 07:40 PM
  5. Non-root Tether Apps Work! :)
    By Jaxidian in forum Droid X Apps
    Last Post: 07-20-2010, 04:39 PM
Z 4 mod
how long does Z4 mod take
how long does the z4root take
how long does z4root take
how long does z4root take to install
how long does z4root take to root
how to use z4 mod
z4 mod
z4 mod root
z4root how long does it take
