[HOW-TO] Theme the GB Lockscreen using Ninjamorph
This is a discussion on [HOW-TO] Theme the GB Lockscreen using Ninjamorph within the Gingerbread Themes forums, part of the Gingerbread Development and Hacking category; Cool thanks a lot. I'll be on the lookout. The lockscreen mod is definitely very cool, got a lot of compliments. ....CM7'd X...
Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 55 of 55
Like Tree4Likes
Thread: [HOW-TO] Theme the GB Lockscreen using Ninjamorph
  1. #51
    Points: 627, Level: 12
    Level completed: 54%, Points required for next Level: 23
    Ch0s3n0n3's Avatar
    32690
    New York
    11
    ....CM7'd X
  3. #52
    3 months registeredTagger Second Class31 days registered100 Experience Points7 days registered
    aju8483's Avatar
    29002
    35
    C Dippa... I think you are right.. I am waiting for my phone to fully charge then I am going to restore my system and then take the CRT,rotation,battery icon zip file and just change the lockscreen background png file. I think this will work because before I would flash CRT then the lockscreen through nm and it would overwirte CRT stuff but still have fragments of the CRT in there causing all sorts of errors. (just my theory) so instead I am going to mod all at once and see if this works.
  4. #53
    Points: 17,058, Level: 83
    Level completed: 42%, Points required for next Level: 292
    Overall activity: 16.9%
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,144
    201 times
    I assume you're talking about swapping them from a computer, which should work. I believe the issue is when ninjamorph recompiles it over that particular CRT mod.
    You should just be able to swap out the pngs you want for the lockscreen in the archive for the CRT mod, and then flash the zip. You can also replace the sliders while you're at it if you want.
    I think you can still use the method in the OP to change the carrier label over that, but haven't tested, so make a backup first if you try that.
  5. #54
    aju8483's Avatar
    29002
    35
    yeah sorry its been a long day and I was not clear... that is exactly what I plan to try (just swap the png's in the flashable .zip ..... first I have to get it to SBF back to stock seeing how I totally F'ed my phone.. will post when I sort that mess out! :-\
    -A
  6. #55
    C Dippa's Avatar
    15008
    Atlanta, GA
    2,144
    201 times
    Quote Originally Posted by aju8483 View Post
    -A
    Do you mean from the CRT mod and this? You should be able to just reflash the deodexed zip...
  1. ninjamorph on .588
    By brewcrewwheels in forum Gingerbread Themes
    Last Post: 05-04-2011, 01:35 PM
  2. Ninjamorph help
    By droiding in forum Droid X Hacks
    Last Post: 01-18-2011, 06:05 PM
  3. Ninjamorph?
    By radioflier in forum Droid X Rescue Squad
    Last Post: 01-06-2011, 04:25 PM
  4. Replies: 5
    Last Post: 11-27-2010, 04:49 PM
  5. Theme with lockscreen sliders for camera and text
    By mpetruzz in forum Droid X Themes
    Last Post: 11-24-2010, 06:54 PM
change lockscreen gingerbread
change system backgroud android using ninjamorph
customize gingerbread lock screen
gingerbread lockscreen mod
how to mod gingerbread lockscreen
lock screen mod gb
ninjamorph change lock screen droid 4
ninjamorph gingerbread lock screen
ninjamorph lockscreen
ninjamorph themes
